Hypermilers thread
i had running boards on my old '96 f150 super cab (perfect length) that i kept.i used one of these.
i flattened it out by running over it with my heavy dually.
anyway.doesn't look half bad either i don't think.
perhaps a few running lights on it sometime to dress it up a bit too.you can see where i used to have some still.not polished up yet,and the holes are still there.(look along the bottom.)
it does need a little more polishing to really brighten it up to match my under body toolboxes on each side.but i can do anytime.
it does make my rusty bumper look worse though haha.
when i eventually replace that bumper (its worse than it looks.there are actually large rust holes on each bottom side now.) i'll do something about adding a clean make shift trim between it and the bumper to really finish it off.
the air dam with my TTB front suspension (f250) and shorter tires: LT225/75/R16 (29.3X8.9) is 9.5" above the ground even still.
pic of behind too.
the running board is pretty near dang perfect,because it has two reinforced bars already.
simply got out the torch and made a couple notches up at the top where i wanted my bends,and bent it around to follow the bumper mostly,and then just drilled a hole on each outside and one in the center and bolted her on.come winter,when its time to hookup the plow,removal is easy as pie.
what do ya think now david85,a row of that soft garden trim edging stuff and it will be just around right? that's what im thinking.something soft (and widely used on the FE forums) that has lots of give to it so i don't stave anything up,and it should drop me nicely below the front axle (my lowest point.)
come on fuel gauge! hang on to full,just that little bit longer now please.
for those interested in why i did this..........fuel economy improvement threads for air dams; these are just a few.search google and check out ecomodder etc. it pays to learn this stuff:
http://ecomodder.com/wiki/index.php/Front_air_dam
http://ecomodder.com/forum/fuel-econ...cations.php#45
http://ecomodder.com/forum/showthrea...ckup-3171.html
fyi,
ford has also wised up,and is providing the new 2011 super duty trucks with lower front air dams.
they are also easily removed for off roading/plowing etc.
one cool report as to the effects on the new super duty:
https://www.ford-trucks.com/forums/1...nt-bumper.html
here's my latest so far,not including this mod:
keep in mind,im 8k lb empty.
this is one of the major reasons why lifting trucks with lift kits/larger tires etc. hurts FE even more,because your introducing even more wind drag under the vehicle.
more hardcore FE enthusiasts will build a whole underside "belly pan" rather than a front low air dam.this way they don't add frontal area,but rather let the wind smoothly flow under the vehicle.
however this is VERY time consuming,more expensive,and to service the vehicle,the whole belly pan,or sections of it,need to be removed and put back on.to top it all off,some don't see any gains at all by swapping their low air dams for a belly pan,or very little difference if they do,and iv even read where one person lost FE and went back to the air dam (this is very vehicle specific.) most don't go through this and opt for the air dam.
like a lot of things,i knew i should have done this sooner.it only took me a couple hrs for crying out loud lol.
now if i see a big jump (half an mpg is pretty dang big today with these fuel prices.if i see just a 10th of an mpg it'll be worth it over time) i'll kick myself for not doing it sooner.
(yeah,i know.she needs a good bath again lol.)
i swear it feels like it goes down the road easier.but it could just be in my head lol.FE records will show if it does or not.stay tuned.
big dave's results was my main inspiration:
Effects Of Air Dam (Ford F350 pickup) - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
27 MPG in an F350 is impressive no matter who you are!
I wonder what electric fans, bed cover, and forward belly pan would do for me..... I'd like to think it could get me another 3 mpg but maybe thats asking a bit much (but I can't be out done by a superduty, can I!? LOL!!)
your truck could do well with the e-fans for what you do,and at your location for sure.
you've been wanting a belly pan for a long time.........just think how much satisfaction you would have if you just set an hour a day aside for it and got it done before cold weather hits.
In all my years of owning the truck, I think I swung them out once or twice. Once was a double wide stack of railings for city hall, and the other time was a load of hay on the same trailer. Could rid of the running boards while I'm at it. Hmm....have I told you lately what a bad influence you are on me?
The fold away style are convex anyway so even though they're smaller, I seem to remember them offering the same amount of visibility when driving my F150.
I'm averaging a little over 19 MPG while towing a trailer. The photos shown here are with a canopy and rather large load, but when I'm getting 19MPG, its without a canopy, and the load in the trailer is below the walls (so aerodynamic drag is minimal). The bed is 20' long, walls are 16" high and it wights about 1500lbs empty to give some idea.
Trailer tires are rated at 35 - run them at 40
Truck tires are rated at 80 - run them at 80
Most important of all, I'm cruising at 55 MPH. With the empty truck running solo, it nets me about 24 MPG
Highest empty was 24.8
Highest with the trailer was 19.7
Empty at 70 I can usually hover above the 20 mark, but I rarely unhitch the trailer so I haven't tested that recently.
