Truck Died
Old Jun 9, 2008 | 11:21 AM
StevensPoint's Avatar
StevensPoint
Truck Died
I sold my '96 F-250 to a buddy a month ago - in excellent mechanical condition of course - and it died on him last weekend. I'll told him I'll go with him to take care of it, but the truck is 2.5 hours away at a relatives house. When we go to get it I want to be prepared with everything it might need. Here's the story:
No previous symptoms. He starts the truck up and gets a couple hundred yards down the road, the truck loses power relatively quickly and eventually dies. He said it felt like it wasn't getting fuel. He swapped the fuel filter and cranked it 5 times in 10 sec. spurts with no luck restarting. Based on my experience restarting a completely drained 7.3, that should just about be enough to get it restarted.
My approach will be to first crank it some more. If that does not do it I will check the codes with my reader. If the codes don't indicate the problem I will replace the fuel pump (mechanical). I may also swap the CPS with the spare in the glove box.
If it still is not running after all that what else should I try?
Any help is greatly appreciated.
Old Jun 9, 2008 | 11:42 AM
Hussler's Avatar
Hussler
Check Fuses ...
Old Jun 9, 2008 | 11:44 AM
Todd525's Avatar
Todd525
I would check fuses before I tried ANYTHING. Then crank a few times.
Old Jun 9, 2008 | 12:08 PM
Action4478's Avatar
Action4478
I would also check the oil level ....
Old Jun 9, 2008 | 12:48 PM
Neal 97 250's Avatar
Neal 97 250
Check oil level in HPOP reservoir. Add if low and start.
Definately change the CPS.
Check fuel pressure with a tire gauge before you change fuel pump. That job is a PITA I hear.
Old Jun 9, 2008 | 01:01 PM
maverick1701's Avatar
maverick1701
X3 on the oil
I had a simmilar situation just last week...turned out there was no oil in the engine. I filled her up and it runs like normal again
