More frontend adjustment
Old Jun 9, 2008 | 09:38 AM
blackimpala's Avatar
blackimpala
A friend has a 92 F250 4X4 w/a 460 that the front tires cup on the inside. He has had it aligned a couple of times and they always tell him that they have adjusted it to the max. I know that the Dodge guys have an after market kit that will allow for more adjustment of the front end. Is there such a thing for his Ford?
Thanks for any help you can give on this.
Floyd
Old Jun 9, 2008 | 09:03 PM
jarod17's Avatar
jarod17
I don't know about a kit for that but where did he have it aligned at? If it was not a quality place they may not be checking the right things. The truck likely has the TTI front suspension. If the front springs have become weak a realignment may not fix the problem. My cousin had a similar problem with his '96 F-250. (now my truck) He put an add-a-leaf kit on it and the problem went away.
It sounds like this may be your friends problem. I suggest putting an add-a-leaf on the front and then taking it to a quality alignment place. They will also tell him if there are any other problems that need to be addressed before they can align the truck.
Old Jun 9, 2008 | 09:31 PM
rowdyredneck's Avatar
rowdyredneck
Also check the axle pivot bushings, if they are badly worn or crushed out of shape it can affect alignment.
fabieber
Feb 16, 2014 05:16 AM
grease monkey
Nov 24, 2004 09:37 AM
F150buyer
Aug 12, 2001 10:50 PM
Motorcraftsman
Ford vs The Competition
25
Aug 8, 2001 12:41 PM
Motorcraftsman
1983 - 2012 Ranger & B-Series
Apr 5, 2001 09:17 AM
