I Am A Idiot
Old Jun 9, 2008 | 06:01 PM
Julies Cool F1's Avatar
Julies Cool F1
Originally Posted by bobj49f2
I would have also made an adapter but the tank sending unit had a smaller hole and I couldn't get the stock float through. I couldn't see a way of combining the two sending units together to make one that would work.
Wow Bob, it sounds like both of our sceintific set-ups were almost exactly the same! Great minds.....(and ours too - tee hee).
I had a problem with my 55 like the one you are discribing above for, I'm assuming, your 49!
In looking at it, I discovered you can use a center grooved/mounted float or an offset (on the end) grooved float. Offset one might go through where the center one won't.
I also discovered that there are a couple that are a little smaller in diameter - usually off foreign cars.
But, if you do use an offset float instead of the centered one, you have to bend the float arm a little in the direction of the groove to keep the stupid thing from dinking on the side of the tank with slosh at every stop light!!!!!
Dink Dink Dink Dink Dink---like to drive ya nuts!
Or, you could probably make a float that would go through using a thin 3/4" copper tube with caps soldered on the ends (water pipe and caps). I soldered it to the arm lengthwise like a toilet bowl float - worked great.
Of course I also installed an emergency three gallon gas bottle on a "camper (twin tank) valve" just in case!
Old Jun 9, 2008 | 06:36 PM
Idaho4rds's Avatar
Idaho4rds
1957 Ford F600
There is a 1957 Ford F600 on ebay for $250.00. Runs good with no rust. Can you believe that???
Old Jun 9, 2008 | 06:57 PM
Mr Mayo's Avatar
Mr Mayo
Bring out the best!
Originally Posted by vintage56
not to put salt in a wound, but being married to an English teacher, it's actually:
"I am an idiot."
in case you're concerned with such particulars...
I too plan to do this tank and am taking notes. thanks for the segway into a tech question; it was a nice scenic route.
JML
if you can't laugh at yourself, who can you laugh at?
In case you're concerned with such particulars, the word is actually "segue". A "segway" is that funny two-wheeled scooter. Your English teacher would agree.
Old Jun 9, 2008 | 07:37 PM
Julies Cool F1
Poor JML!
Did you give the guys on the side of the road the FTE address....poor guy, seems like the abuse never ends!
I'm here for ya buddy!
J!
Old Jun 10, 2008 | 12:58 AM
vintage56's Avatar
vintage56
good form Mayo. I hoped somebody'd get that.
laughing at myself.
JML
Old Jun 10, 2008 | 06:53 AM
Last Chance 56's Avatar
Last Chance 56
I will have to check the specifics on the VDO gauge that I am using and verify that with the info that I recieved here(Thanks guys and gals). I believe that my problem is the rotation that I installed the sending unit, since it is mounted on the front lower end of the tank. I will check that out first and break out my cardboard beer box (should be able to find one of those around here). Again thanks, I will let ya'll know where I get.
Old Jun 10, 2008 | 12:09 PM
WALFORD'S 56's Avatar
WALFORD'S 56
That is what ya get for goin' custom,Rodney--haha!! I am glad truck ran good with the wife in it, she is not fond of break-downs--haha! I hope you figure it out!! Bill
Jon003
Mar 24, 2022 04:02 AM
SSellers
20
Dec 24, 2013 12:47 AM
biggyfan1
Oct 28, 2013 11:22 AM
86'F-150
84
Jan 22, 2013 10:33 PM
79F250RepoTruck
Mar 22, 2012 07:36 PM
