Blowby!
Old Jun 8, 2008 | 05:19 PM
N7ghtwolf's Avatar
N7ghtwolf
Blowby!
A little over a month ago I started to notice some blowby, its gotten worse but I have no idea whats causing it. Compression is close to perfect in all cylinders!
What else causes blowby? I know my timing has been needing to be checked for a while now!
Old Jun 8, 2008 | 05:39 PM
srercrcr's Avatar
srercrcr
Blowby is simply crankcase fumes getting past worn piston rings. If you have it, you have worn rings, which means you have poor compression.
Where are you seeing this blowby? Is the PCV valve and line hooked up?
Old Jun 8, 2008 | 09:39 PM
fmc400's Avatar
fmc400
MSEE
Right on the money. Check PCV valve and breather filter, as well as respective lines.
Old Jun 12, 2008 | 01:16 AM
Redneck-Cowboy's Avatar
Redneck-Cowboy
Yeah hopefully it's just your PCV system. When I started gettin major blowby outta my engine I couldn't figure out what was going on either since the comp was still moderately good for 300,000 miles, so when I did yank it (startin to tick/knock under a load) I found a broken ring land on the #6 cyl, didn't mess up the wall though, the piston just fell aprat when I pulled it out of the cylinder......lucky.
F-250 WARHORSE
20
Sep 17, 2017 09:46 AM
Snappy_
Apr 4, 2017 06:59 PM
DieselCamper
Aug 15, 2016 11:36 PM
SidecarFlip
Transit Connect
24
Apr 17, 2016 08:50 PM
LonW
Jan 9, 2010 10:10 AM
