bad blow-by
Old Jan 7, 2010 | 01:50 PM
LonW's Avatar
LonW
bad blow-by
The smoke coming out of my heater turned out to be excessive blow-by (out of the breather cap and even the dipstick tube) being sucked in. The PVC valve rattles and has flow only in the proper direction and I seem to have sufficient vacuum at the manifold, and can't find any blockage. If this blow-by is a recent development (oh woe is me), why aren't I laying down a smoke screen out of the tailpipe? BTW, it's the 'Mileage Maker" I6 (223). Thanks for the help even if it's bad news.
Lon
Old Jan 7, 2010 | 03:52 PM
Bill W's Avatar
Bill W
maybe a broken ring? that would be just a guess, i would do a compression test to see if there are any low cylinders
Old Jan 7, 2010 | 04:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by LonW
The smoke coming out of my heater turned out to be excessive blow-by (out of the breather cap and even the dipstick tube) being sucked in. The PVC valve rattles and has flow only in the proper direction and I seem to have sufficient vacuum at the manifold, and can't find any blockage. If this blow-by is a recent development (oh woe is me), why aren't I laying down a smoke screen out of the tailpipe? BTW, it's the 'Mileage Maker" I6 (223). Thanks for the help even if it's bad news.Lon
When the PCV system is present, there is an adapter at the rear of the engine that takes the place of the road draft tube.
Inside that adapter is a filter screen (B2TZ6A631A).
Since next to no one today knows there's a filter back there, it rarely gets changed, and so...it's prolly clogged up.
If it's not the filter, the rings are shot. Blow-by with the 223 engine was/is somewhat common...even when these trucks had only 40,000 or so miles on them.
btw: The 223's & 292's used the same filter with a road draft tube...or with the adapter.
Old Jan 7, 2010 | 05:23 PM
LonW's Avatar
LonW
blow-by
Boy, there is no joy in Mudville. I pulled the adapter after I checked the PCV valve and the screen is absent. I'm probably just trying to avoid the obvious. I chewed up a ring and piston about a year and a half ago in #5. Since we were already into our little 'recession' I preferred to leave the cash stashed in the mattress and went with a minimal repair route. The kids in AutoMech at the Jr. College I work at did it for the cost of parts. The instructor thought the wall scarring was minimal enough that without boring I'd be able to get away with just a little oil use, which was the case until just a few days ago. Thanks for the input, guys.
Lon
Old Jan 7, 2010 | 05:32 PM
starmilt's Avatar
starmilt
I have dealt with partsmen and women all my life and there are partsmen that do a good job then there are PARTSMEN that you could tell them what part you need and they grab it off the shelf with out looking at a book or later a computer.
Then I got one a couple years that said there was never a dimmer switch on the floor so she would not waste her time looking it up.
I just wanted to thank you for the info you give out and for your time,I have a feeling you were in the small percentage of the great partsmen.
Old Jan 7, 2010 | 06:58 PM
Big Daddy T's Avatar
Big Daddy T
I'm with Bill. Do a compresion test and compare all cylinders before you get too excited but if youve already had trouble you may be right, Hope it turns out simple!
Old Jan 8, 2010 | 03:51 AM
NumberDummy
I didn't waste any time lookin' this up...cuz I memorized the number 46 years ago...
COTZ13A024A .. Dimmer Switch - Foot Operated (Motorcraft SW263) / Fits a gazillion car/truck applications 1960/96.
Old Jan 8, 2010 | 07:25 AM
Flyn66dtmn's Avatar
Flyn66dtmn
my 2 cents, blowby is also commonly caused by worn valves releasing gases into the valve cover area. it gets especially worse when the valve rubbers are old and broken. i agree with the rest of the fellers, do a compression test. also a trick i learned a few years back. take a old sparkplug break out all the glass liner so all you have is the threaded nut part and weld a hose connection onto it so you can pressure the cylindars. you can then pressure up your cylidars with an aircompresser . if you hear air weasing into the valve cover ares it the valves that are bad, if it's coming out the tailpipe then its rings. it has made a big difference in my choices of whether i have to work on the top end or the bottom section. this willl also help in telling you whether it is exhaust valves or intake valves. Dutch
Old Jan 8, 2010 | 11:26 AM
46yblock's Avatar
46yblock
B2TZ6A631A does NOT fit anywhere on or in any component of a 292's PCV system. It is far too large. It fits the earlier cannisters of the side mounted road draft tubes.
Old Jan 8, 2010 | 12:29 PM
46yblock's Avatar
46yblock
Here is a pic of the PCV system components and the too large filter:
It would be nice to find a filter that fit, but I havent seen one in 7 or more pans that I've had. Check your metal line, it is probably clogged.
Old Jan 8, 2010 | 06:56 PM
starmilt's Avatar
starmilt
Blow by is rings pressure comes to the valve cover. bad valve seals smoke goes out the exhaust.
Old Jan 9, 2010 | 10:10 AM
grahamS53's Avatar
grahamS53
Compression test her, pour some oil into the cylinders showing low, retest. Increase in compression piston/rings related. No increase in compression head/valves related. Just something i have always done and just corectly diagnosed a ring problem in my Fury's 383 motor.Thought you might be interested.G
CISKOWSKI_21
6.4L Power Stroke Diesel
18
Apr 20, 2020 07:54 PM
DieselCamper
Aug 15, 2016 11:36 PM
radarweaver
Jan 9, 2011 02:32 PM
kane gray
Jan 19, 2009 10:44 PM
fmc400
Feb 2, 2007 09:15 PM
