Constant power to trailers running lights
Old Jun 8, 2008 | 03:25 PM
amckinney34's Avatar
amckinney34
Hi all,
Need help!
I have just noticed that I have constant power to my trailer running lights on the 7 &4 pin connectors I have a 2005 F250 SD.
I have pulled all the relays and the running light pins still have constant power the only way to remove power is to pull fuse 38 which cuts power to the connectors.
The lights on the truck works fine it's only on the trailer connectors i'm having the problem with. Not sure where the problem is.
I been told that I may have to replace my CJB "Control Junction Box"
I'm planning to leave for vacation Tuesday will this hurt my truck or camper during hauling? Any help will be appricated.
Thanks,
Amckinney
Old Jun 8, 2008 | 04:57 PM
Steina's Avatar
Steina
CO River Rat
Did it work OK before and this just started?
Steve
Old Jun 8, 2008 | 07:34 PM
amckinney34
Steve
My wife pulged in the 7 pin connector upside down and drove the camper awhile I then found that fuse # 38 was blown I replaced the fuse and this when I started noticing the problem. The truck lights work fine and the trailer lights for the turn signals work ok too.
Thanks,
amckinney
Old Jun 8, 2008 | 09:53 PM
Steina's Avatar
Steina
CO River Rat
Thinking the upside-down plug jammed some pins in either the truck or trailer connector, or maybe fried a relay closed; now you're getting constant voltage where you shouldn't.
Steve
Old Jun 9, 2008 | 05:58 PM
amckinney34
Steve
The problem is in both plugs 4 & 7 I've been told today that the problem is most likely my central junction box Is this the main fuse box or the one under the hood?
amckinney
Old Jun 9, 2008 | 08:12 PM
Greywolf's Avatar
Greywolf
I'm trying to picture what happens and where power goes when the seven way is 180 degrees upside down.
-It isn't a good thing, I know that.
The turn sigs would be unaffected. (just backwards when turning)
Direct 12V would go into the running lights. Running lights of the truck would be applied to the RV battery.
The brake power supply output would go directly to ground (from the controller).
The brakes themselves would not work (in the trailer) but this would not hurt them.
Near as I can determine, the main thing affected would be a dead shorted high ampere signal out of your brake controller.
I bet it fried, and took something else with it..
I'm still puzzled about how a seven way with a notch as big as it is can be rammed in topsy-turvy....
It's impossible with a four way flat - it just won't go!
Old Jun 10, 2008 | 07:54 PM
amckinney34
I'm almost sure that the relay for the running lights in the CJB has been shorted which means it has to be replaced. Does anyone know the list price and location of the CJB?
Thanks,
Amckinney
Old Jun 10, 2008 | 08:14 PM
Greywolf's Avatar
Greywolf
If worst comes to worst (in fact post that item there anyway) the FTE Electrical forum almost always provides fast results from a LOT of professionals if the post and title are direct to the point.
I guarantee you that you are not the first to have this happen - you didn't "INVENT" this one, okay?
We've got a lot of amazing people in that forum.
Relax, post that note, and check on it. I bet you get an EXACT location, price, alternatives, several choices of where to get it and how to have it tested before spending any cash within 24 hours.
~Greywolf
Old Jun 10, 2008 | 08:49 PM
amckinney34
~Greywolf
Thanks and God bless.
rusbukt
All Things Towing
17
Feb 12, 2016 01:35 PM
sammie0126
1997 - 2003 F150
46
Dec 3, 2013 05:10 AM
mitsudave
1997 - 2003 F150
13
Oct 24, 2012 06:27 PM
secolvin
All Things Towing
Sep 28, 2011 04:00 PM
Capitlj
Nov 4, 2009 07:13 AM
