i have a magnaflow exhaust that has been fine ever since i got it in 2005.
but now when drive and start slowing down it makes this terrible shaking/clanking noise like its dragging or breaking but it stops as soon as i speed up {above 1,000 RPMs}.
I thought it was because it was just loose but its not and it also makes the noise when i let it idle roll.
Do After-market Exhausts "die-out" or is it a engine problem you hear from the exhaust?
-Fenton
It could also be the loose or disconnected bolt studs that connect the exhaust manifold and exhaust collector pipe. Check both the drivers and passenger side connections.
