Weird steering behavior. Help needed.
Old Jun 7, 2008 | 10:47 PM
CTHal's Avatar
CTHal
My 1993 F150 4x4 with power steering has developed a weird steering problem. After it warms up, when I go around a turn, the wheel does not go back to straight unless I 'force' it to go, and sometimes the wheel feels like it is being pushed one way and then the other. Occasionaly while going straight, all of a sudden it will feel like it dives to one side, then back the other way, and oscillates like this 5 or 6 times. If I turn the wheel to the left or right, it stops.
I put the truck up on jack stands on the frame, and checked the ball joints, tie rod ends, drag link etc, and nothing seems to be loose, floppy or clunking. Is it possible that there is a problem with the steering box/steering pump?
As a note, the power steering fluid looked kind of dark and cooked. I changed the fluid and the problem improved slightly.
Thanks for any guidance. Hal in CT
Old Jun 7, 2008 | 11:33 PM
all4ford's Avatar
all4ford
If it improved after changing the fliud I would guess it could be the pump causing the issue. Just a guess though. Since knowone else has replied. Maybe check the lines and make sure none of the steel lines are pinched or smashed.
Old Jun 8, 2008 | 05:37 AM
alz's Avatar
alz
Check the axleshaft u-joints. Even though you are not using the 4x4, the joint still needs to pivot when you turn.
Old Jun 8, 2008 | 09:07 AM
lostin90s's Avatar
lostin90s
What ALZ said .. I just did them . As well as ball jionts. As when u pull axels the ball jiont r just a step away from them .
Sidener
Feb 10, 2014 08:18 AM
5.4L to Freedom
Feb 13, 2011 03:55 PM
Mr86GT
2004 - 2008 F150
Jul 25, 2009 01:27 PM
jdman1
Feb 3, 2008 07:27 PM
LuNaTIcFrEAK
15
Apr 6, 2007 12:19 PM
