AIH delete
Old Jun 7, 2008 | 07:43 AM
Bin Strokin's Avatar
Bin Strokin
AIH delete
so i was thinkin of removing the AIH but was wondering how much this heater actually aids in starting the truck.
im not too worried about it in the summer but the winter months can get kinda cold up here.
any input?
Old Jun 7, 2008 | 08:05 AM
Pocket's Avatar
Pocket
The AIH does not help with starting at all, and it does not aid in warming up the engine. The sole purpose of the AIH is to reduce white smoke on cold idle by bringing in warmer air into the combustion chamber. However, it only kicks on under certain conditions: in cold weather, with the truck in park (or neutral with the e-brake for sticks), high idle has to be activated, and the glow plugs must be off. In many cases, the glow plugs can stay on for up to 2 minutes after you have started your truck, so the AIH is off during that time. As soon as you start driving, the AIH shuts off as well.
As for the amount of white smoke that it helps reduce, that's debatable. I really didn't see much of a difference after taking mine out. Some have noticed only a slight difference. For reference, the older 7.3L's and the Van PSD's don't have it, so getting rid of it won't hurt anything.
Old Jun 7, 2008 | 08:08 AM
Bin Strokin
cool thats just the answer i was lookin for, and from what ive read its quite big, so when removed it must improve some air flow, right?
Old Jun 7, 2008 | 08:10 AM
Ponyboychris's Avatar
Ponyboychris
Like Pocket said, it's not needed and for the couple bucks for the plug, get rid of it. The heater element is rather big so if anything, you'll feel better knowing it's not in the way of getting air into your engine. I didn't see any seat-of-the-pants power improvement but it's got to have some benefit having it out of there.
Old Jun 7, 2008 | 11:08 AM
aklim's Avatar
aklim
One major benefit is that with it removed, you can buy the plug with a port for a boost gauge and it will be pretty accurate.
Old Jun 7, 2008 | 11:55 AM
Automator's Avatar
Automator
OK, being new here, what is the AIH and what would deleting it do?
Old Jun 7, 2008 | 12:29 PM
aklim's Avatar
aklim
It is an intake air heater. See post 2.
Deleting it does 2 things. Free up an obstruction and gives you a place to hook a boost line to so you can get actual manifold pressure.
