Throwing a code on decelleration
Old Jun 7, 2008 | 01:58 AM
outdoormaniac's Avatar
outdoormaniac
Passin traffic today, so i had my foot in it pretty good and once i let off my SES light flashed once quick. Not sure if it even threw a code, as the light just flashed real quick and didnt stay on. Any ideas?
Also, sometimes when i start and go my speedo wont work and my Overdrive light is flashing. Whats the flashin O.D. light mean again?
Thanks.
Old Jun 7, 2008 | 02:32 AM
rob188's Avatar
rob188
alot of 7.3 flash on cold start, same with hard shift, once it warms up it should stop right? or you've got a preoblem in your tranny,
Old Jun 7, 2008 | 08:44 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You might want to take off and clean your SSV sensor on your rear end. Make sure the connection is good and tight. That is your speed sensor, and the trans needs to use it.
