Water temp- yes there is a plug just under the thermostat housing on the drivers side
Oil pressure goes where the supply hose is pictured here. Its actually 1/8 pipe not 1/4 like i have it labeled
Voltmeter- I would go to the fuse panel and find one that on with the key
