Yes, another 4R100 trans fluid thread!
For those of you who don't know who Greg Evans is, he is an ex-Ford transmission engineer and is currently the designer of the Factory Tech Monster Box for the 4R100 as well as other transmissions like the Torque Monster for the 5R100.
Anyway, his reply was short and sweet, "Use only MERCON III/DEXRON, never use MERCON V in a 4R100".
There you have it, take it for what it's worth but I'll take the advice/direction from someone who designs and builds transmissions for a living over that of a transmission shop that doesn't have a clue or a backyard mechanic any day of the week.
With all due respect to trans repairmen, and I've known several, they are not familiar with the testing that goes into certifying a fluid for use in a transmission. Gregg is quoting old information.
MERCON V has changed from the old formulation. It is now the right fluid to use in a 4R100. I was one that OFTEN stated not to use MERCON V in a 4R100 (see my article on changing ATF in the 4R100), but things have changed.
2. MERCON V has changed from the old formulation. It is now the right fluid to use in a 4R100. I was one that OFTEN stated not to use MERCON V in a 4R100 (see my article on changing ATF in the 4R100), but things have changed.
2. So how is someone to know if a shop is using the old formula that they've had stock piled or the new formula.
You know there's no such thing as MERCON III, right?
It's MERCON/DEXRON III
There's MERCON and MERCON V. Nothing else
aldridgec
Posting Guru Join Date: Mar 2002
Quote:
Originally Posted by kenneBF250V10
Here is a paragraph taken directly from TSB 06-14-4:
ACTION:
Beginning immediately all automatic transmission / transaxle applications requiring MERCON® can now be serviced using MERCON® V or MERCON® Automatic Transmission Fluid or dual usage fluids labeled MERCON® / MERCON® V. After July 1, 2007, MERCON® Automatic Transmission Fluid will no longer be manufactured, therefore, availability of this fluid will only continue for however long it takes to deplete what remains in inventory.
So according to this TSB, MERCON V is ok to use in the 4R100. If that's the case then why did a shop foreman at a Ford dealer tell me that MERCON V in a 4R100 is a big no-no.
If MERCON was supposed to be no longer manufactured after July 1, 2007 then why can you still get it from Ford? You mean to tell me that they had that much stockpiled.
Yep that is the TSB I looked up. And we now have updated info from Mark as to the info in the writeup. Case closed it looks like.
Looks like the OP lucked out in getting and upgraded warranty, score one for the dealer stepping up and getting it done, and switching to a different fluid like he wanted.
However, looks like they were doing the right thing afterall.
__________________
ASE Certified Master Automotive Technician
Current Vehicles:
2002 F-250 7.3L PSD 4x4 XLT
2002 Sunset Orange Mettalic WS6 Trans Am Convertible
"Maybe is for those who lack skill"
Not sure how to insert a quote so I cut and pasted, but you get the idea. Remember this one Marc?
There's MERCON and MERCON V. Nothing else"
Seems like you missed a chapter or two in this process. First there was "type A", then Ford type F came into being. The next thing that happened is that type A became known as /was replaced by Mercon, then Mercon II, then Mercon III. GM used the name Dexron for Mercon. Then Mercon/Mercon III was replaced by Dexron III. Mercon V was orginally a synthetic fluid and was NOT for use in Dexron/Mercon transmissions. Then Mercon V was reformulated and rated for replacement of the Dexron/Mercon brands. I still have a few quarts labeled "Mercon III" in my garage. If you go to AutoZone, you can purchase fluid with a label that states for use in transmissions requiring " Mercon III". I have been rebuilding transmissions for more than 25 years and may be a little more familiar with this than some.
There NEVER was a MERCON II, MERCON III, or MERCON IV. There has been MERCON, MERCON V, and MERCON SP.
MERCON and DEXRON III were almost identical fluids, so any fluid that met one of those specs met the other. They were all labeled MERCON/DEXRON III.
The factory fill MERCON V was NEVER a synthetic. It is a synthetic blend. There are dino MERCON Vs, blends, and full synthetics available.
