2003 Expedition slow to start
Old Jun 4, 2008 | 10:30 PM
randinow's Avatar
randinow
I have a 03 Expy with the 4.6 engine. When I go to start the truck, it will turn over for several seconds before it will start. I have had the problem for a couple of years. Ford said I needed a fuel pump, independent mechanic said it wasn't that bad at all, and he wouldn't touch it until it got worse. I have noticed since it has gotten hot outside that it seems to be worse. Now sometimes it seems like it's never gonna start. Any suggestions on what this might be?
Old Jun 5, 2008 | 08:24 AM
ronjeremy6's Avatar
ronjeremy6
sounds like it's gotten worse, so check the fuel pump and fuel filter.
Old Jun 5, 2008 | 11:02 AM
pdqford's Avatar
pdqford
When you go to start it, first turn the key to the "ON" position for a few seconds and then turn the key to the "OFF" position. DO this a couple of times and then try to start it. If it fires right up, your fuel pump check valve is leaking (or you may have a leak in one of the fuel lines.)
Old Jun 6, 2008 | 04:00 PM
randinow's Avatar
randinow
So does fixing the fuel pump check valve mean replacing the fuel pump? or does that require the same amount of work?
cdrmotorsports
Nov 11, 2014 09:43 AM
Brett Baxter
Aug 26, 2014 09:25 AM
makuloco2000
2004 - 2008 F150
Jan 16, 2014 12:00 AM
gard107
Jan 8, 2009 03:43 PM
supertim
Nov 2, 2002 04:57 AM
