Fuel & Spark
Old Aug 11, 2009 | 04:58 PM
Rothschild's Avatar
Rothschild
MY TRUCK IS RUNNING!!!!!!
After checking the bulbs, I went through all the wires and fuses under the hood. Yes, I found a bad wire to the solenoid. After fixing, I turned the key and saw the check engine light come on, then turned and the truck fired up like there was never anything wrong.
Thank you very much for the support!
It runs a little rough now, but thats minor compared to what I went through. I also found a missing vacume line. The pc valve has a thick lower hose and a thin upper hose. The upper hose is missing and I can hear the air hissing. Where does the upper hose to the pc valve lead too? I can't seem to find where it would go.
lamarbEzy
1978 - 1996 Big Bronco
May 9, 2014 04:44 AM
simmonds1970
15
Feb 24, 2012 10:44 PM
Jordanz_03
Dec 18, 2010 05:26 PM
AlaskaBronco
Mar 12, 2003 12:41 AM
rynbrn
Bronco II
May 10, 2002 07:56 PM
