Broken Push Rod Cluth master 1996 F150
Old 08-11-2009, 08:00 AM
mgb75
mgb75 is offline
mgb75 is starting off with a positive reputation.
I have a 1996 F150 5 speed, about three weeks ago the pushrod broke at the bushing (all plastic) I replaced the master and yesterday it broke again, there didnt seem to be any extra resistance that would have caused ot to break. Does anyone have any idea why this broke?
Old 08-11-2009, 09:13 AM
timbersteel's Avatar
timbersteel
timbersteel is offline
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
Just curious, did you replace with OE or something other than Motorcraft? I've heard a lot on here say that for anything related to slave or master cylinder if it isn't Ford quality, it won't last long(relating to the slave or master cylinder).
Just a thought, hopefully FTE can help you further.
Matthew
Old 08-11-2009, 05:04 PM
qman
qman is offline
qman is starting off with a positive reputation.
Are you saying the pushrod broke or the plastic bushing that holds the rod to the clutch lever broke?
If it's the bushing that's breaking, it's probably cuz the shaft bushings are worn and the the shaft is tweaking. Check the push rod eyelet and steel piece that sticks out of the clutch lever for wear. If there's wear in there then things won't operate smoothly.
Billsfan
1999 to 2016 Super Duty
10-11-2016 07:46 PM
lacyctdy
05-02-2016 08:38 PM
1vannn
08-05-2015 05:29 AM
oldfordtrucksrule
1997 - 2003 F150
03-10-2015 08:02 AM
marragtop
10-10-2008 08:46 AM
Quick Reply: Broken Push Rod Cluth master 1996 F150
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
