Sponsored by: Real Truck
Steering dangerous
Old Jun 3, 2008 | 11:33 PM
jim6liter's Avatar
jim6liter
Steering dangerous
Well this is wierd, if I'm turning full to the right and then go to turn left,the truck will straighten out but will not turn left untill I nudge the wheel to the right.Then it will go left just fine.I looked at the front linkage and all looks fine. By the way its lifted.It just started this recently with 25k miles on the lift. Any suggestions where to go first? Thanks for reading!
Old Jun 4, 2008 | 12:36 AM
Heavy_Metal's Avatar
Heavy_Metal
Time for a steering gearbox.
Old Jun 4, 2008 | 09:58 AM
jim6liter's Avatar
jim6liter
okay,thanks. How long should a box last? I have 57,000 miles on her.
Old Jun 4, 2008 | 10:40 AM
rugermack's Avatar
rugermack
At 57k , I would make sure your steering stabilizers aren't bent or something else first. That's low miles for a steering box. Mine is original and is pushing 156k.
Old Jun 4, 2008 | 11:04 AM
jim6liter's Avatar
jim6liter
I did a visual and everything looks good.You talking about the Steering shock?
Old Jun 4, 2008 | 11:15 AM
redford's Avatar
redford
FTE Leadership Emeritus
Yes - that shock looking thing is the stabilizer.
Old Jun 4, 2008 | 11:22 AM
jim6liter's Avatar
jim6liter
I'll pull the stabilizer off and see if the problem goes away.
Old Jun 4, 2008 | 11:27 AM
rugermack's Avatar
rugermack
Ford puts that stabilizer real low to the ground. I've taken out two already. I have since relocated it with some new brackets and haven't had any problems yet. In Az there are alot of rocks. I hope that's your problem.
Old Jun 4, 2008 | 11:31 AM
jim6liter's Avatar
jim6liter
yeah, I hope its that simple. Thanks
Old Jun 9, 2008 | 10:52 PM
jim6liter's Avatar
jim6liter
Well I just got around to pulling the stabilizer and the problem is still there.So I guess a steering box is in need.Any other places to look first? Thanks! Also is there a good place to order the box from?Or the dealership?
Old Jun 12, 2008 | 11:36 PM
jim6liter's Avatar
jim6liter
For anyone that cares.steering gear box fixed the problem.Thanks--- Heavy_Metal
Old Jun 13, 2008 | 12:13 AM
jake00's Avatar
jake00
did you install it yourself?
Old Jun 13, 2008 | 12:30 AM
Heavy_Metal
You're welcome. Steering gear can go at any time on these things, I've seen them get stiff at 20k (mine did on my '99 at 22k). Just depends on how much you "strain" your steering. Big tires, snow plows, lots of off roading can tear them up quick.
Old Jun 13, 2008 | 09:25 AM
jim6liter's Avatar
jim6liter
Yeah,installed my self with the help of a buddy.
