ac:replacing it all
Old Jun 3, 2008 | 08:57 PM
bnb29's Avatar
bnb29
ac:replacing it all
92 F 150 5.0L
Factory r 12
I've been running 134 for 2 years. Compressor finally quit. Not locked but not pumping.
I'm going to flush the evap. and change everything else.
Going to try a variable oriffice.
My ac manual says the system had 7 ounces of mineral oil for r 12.
Should I use 7 Ounces of PAG 46 in my fresh system?
Old Jun 4, 2008 | 12:20 PM
projectSHO89's Avatar
projectSHO89
Stay with the fixed orifice, use the correct size for the conversion.
Hopefully, you have made certain it's not a clutch (or clutch control) failure.
Yes, use 7 oz of PAG 46 in the system. Distribute it into the components, ie, pump, new accumulator, and the condenser.
If you do indeed have internal compressor failure, it probably grenaded and you'll likely need to replace everything forward of the firewall.
Steve
Old Jun 4, 2008 | 01:59 PM
hhott71's Avatar
hhott71
Originally Posted by bnb29
92 F 150 5.0L
Factory r 12
I'd use 7 oz of ester oil, a new accumulator and all new o-rings and springs.
A replacement 94 orifice tube may work well for you.
Also adjust the CCOT switch about 1/4 turn CCW (screw out 1/4 turn) and charge it to 33 oz of R134.
Old Jun 4, 2008 | 08:02 PM
bnb29's Avatar
bnb29
Everything will be changed but the evap.
With the new system do i still need to use ester?
when it was working, i had 40 degree vent temps at 88 degree ambient.
My orifice is blue. Are you saying a red orifice will operate better?
Old Jun 4, 2008 | 08:09 PM
bnb29's Avatar
bnb29
By adjusting the pressure switch ccw is that lowering the cut off pressure?
tarkster
Sep 19, 2014 09:54 AM
tarkster
New Member Introductions
Sep 15, 2014 02:23 PM
joelfx4
Aug 12, 2010 12:56 AM
fcarruth
1978 - 1996 Big Bronco
Jul 16, 2004 09:38 PM
M.Herrington
Aerostar
Jun 2, 2004 09:18 PM
