Carb questions
Old Jun 10, 2008 | 01:44 AM
fasthauler's Avatar
fasthauler
I have put decimal drill bits in my dremel and drilled out jets in emergencies when I haven’t had the proper size jets available. I haven’t a clue as to what would use #39 jets in a 735cfm carb. That is a lot of air with very little gas.
Old Jun 10, 2008 | 09:18 PM
peganit2's Avatar
peganit2
Got 62's and 66's in it and it's running MUCH better!
Thanks guys, this is an excellent site.
Old Jun 16, 2008 | 12:40 PM
wdfp's Avatar
wdfp
Sorry I could not get back to you in a short time but sounds like you are on the right track anyway, After you drive it a ways pull a few plugs and make sure you are not too lean as those jets work well in 600 cfm carbs and may be a bit lean for one over 700 cfm. But the spark plugs will tell you what you need to know. Hope it runs good for a long time!
swolh
27
Feb 8, 2015 10:45 AM
imlowr2
Aug 28, 2008 01:51 PM
hoxiii
Sep 8, 2006 03:56 PM
drive_old_ride_new
Dec 3, 2004 01:43 PM
1970f2504x4
35
Dec 25, 2003 10:14 PM
