fuel gauge question
Old Jun 1, 2008 | 02:17 PM
76f250highboys's Avatar
76f250highboys
fuel gauge question
I have a 1985 f150 with the front side tank. I am trying to get my fuel gauge to work. I am able to access the sender by dropping the driveline and am able to reach sender from the top without dropping the tank. With a meter, is there a way to test the sender to see if it works? Thanks for any help.
Old Jun 1, 2008 | 03:20 PM
rbaker6336's Avatar
rbaker6336
ground the guage wire,guage should read full
if the guage reads full the problem will either be sender or ground going to it
Old Jun 1, 2008 | 04:22 PM
76f250highboys
Thanks Ray. I grounded the wire and gauge went to full. Im now tracking down a new sender. napa only had an aftermarket universal unit and lmc trucks was 79.95. Anybody know of one for less let me know. Thanks.
Old Jun 1, 2008 | 04:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Here's your alternative choices.
Ford lists two different fuel tank sizes and senders for your application.
(1985/86 F150/350 non EFI 6 or 8 cylinder gas engines exc. 460-mid-ship [front] tank)
E5TZ9275G .. Fuel Sender / Use with 19 Gallon Mid-Ship Tank
MSRP: $102.98 / ftepartsguy.com price: $74.15
E5TZ9275H .. Fuel Sender / Use with 17 Gallon Mid-Ship Tank
MSRP: $151.00 / ftepartsguy.com price: $108.72
That 80 buck sender might be lookin' pretty good right now...
...but is it the correct one?
Old Jun 1, 2008 | 06:35 PM
76f250highboys
Thanks Bill for the research. I think I will be calling LMC TRUCK in the morning to make sure. Pretty sure I have the 17 gal tank as I have filled it from empty enough times. The number on my old sender is E5TE JA if that helps. Thanks
Old Jun 2, 2008 | 01:20 AM
NumberDummy
Ford lists a part number of E5TZ-9275-JA, but it's for an F250/F350 with a 351W 4V or 460...someone may have changed yours to this one years ago.
I have no cross reference, so I'll call a pal on Monday and verify that E5TE-JA engineering number translates to the E5TZ-JA part number.
This p/n is obsolete but 10 dealers across the US have one. Since it's not the right one, I personally wouldn't worry about it.
Troyus
15
Feb 26, 2017 11:40 AM
petermck
Nov 21, 2016 06:33 PM
acoultha
1966 - 1977 Early Broncos
Nov 21, 2016 05:52 PM
baverwolf
Mar 13, 2016 11:22 AM
KG Excursion
Jun 27, 2014 07:59 AM
