Trip
If your tires are rated LT and a max of 50psi boot the pressure up to 42psi [any more gives a rather rough ride] to improve fuel economy.
What does your serpintine belt look like, any cracks? If so, replace it now at your convience, or possibly do so on the roadside at your inconvience.
When was the last time you changed your airfilter?
Last, but maybe not least, install a scangauge on it to give yourself a reality check on your driving habits and fuel economy. I suspect that it will pay for itself in less than one year. My truck is pre obd2 so it won't work on mine or I would have one.
Fresh batteries for your flashlight. Jumper cables. I started buying AAA Club membership, the highest level-because they will do one tow of up to 200 miles, and here in Texas the short distance limitations on most other plans are a joke! I used AAA once in Wyoming to tow my Mazda B2000, which had blown a head gasket, to the nearest dealer, which was over the mountains in Idaho, 100 miles away. No problem.
Here in Texas, I started subscribing again , then within the first year the transmission went out on my F150 45 miles from home, and they came and towed it to my trusted shop. Its great piece of mind, and my Premier Level membership runs $125.00 a year, plus has other benefits, but I buy it for the towing assurance....and all the free maps I want at their AAA Centers.
With 107K on it, it should be ready for a major scheduled maintenance, so I'd get it up to date on all past & present due scheduled maintenance call outs.
All synthetic lube fluids might be a worhwhile consideration.
If your going to be carrying a load, or towing & have a auto tranny, maybe consider adding a tranny cooler, if you don't already have one.
Probably time for new coolant hoses, including the heater hoses too. So while doing that I might pop in a new thermostat, if it hasn't been replaced in the 107K.
When you replace the belt, put the old one under the seat as a spare, just in case!!!!
Use good gas & enjoy your trip!!!!
Let us kow how it goes.
