Thanks guys, not sure on the wide track front end. I think it has it, but I did not end up with the window sticker. Heck of a truck, wife likes driving it, thought she wouldn't but she says she likes driving it better than the 05.
John, is there any way to get a build sheet or specs online?
Call Ford Customer Service and they will give you a build sheet. Almost the same as the invoice/window sticker. You can also get a copy of the owner's manual from the same folks. If you do not have the books, call and get them. Remember to only use: ULSDF, aka, Ultra Low Sulfur Diesel Fuel, 15 PPM sulfur.
Good luck, and hope your truck is as good as mine.
Post your VIN over in the vehicle locator section at BOF. The main poster over there (ViperPilot) should be able to provide you with a PDF copy of your window sticker...
