Speaker Grilles
Old Jun 1, 2008 | 09:33 AM
Soccer85's Avatar
Soccer85
Speaker Grilles
I have a 2006 Scab FX4 and I've tried taking off my speaker grilles and was successful on the front, you know they just pull off, but what about the rear? I tried pulling them but they don't seem to want to move and i don't want to pull to hard and break them because they're not supposed to be pulled off.
Old Jun 1, 2008 | 02:25 PM
AceSC's Avatar
AceSC
That's because those don't come off. In order to get to the rear speakers you will have to remove the whole door panel. It sounds a lot harder than it actually is, believe me. You should start up on the long piece of trim that runs vertical along the window, pull on it and it snaps right off. Once you got that off you will see a couple of fasteners. After that you should remove the small rectangular cover where the door opening handle is, behind it you will find more fasteners. There should also be a few more fasteners towards the very bottom of the door. Once you got all the fasteners off, you pull up on the door panel and it snaps right off easily. Remember to pull up and not away from the door. Once you got the door panel off take a flat heat screwdriver and loosen the door handle, just pry a little bit against the black plastic part from the rear of the door panel and it should also slide right off. When your ready to reinstall remember you will have to slide the panel on from the top down. I found it very simple to do this even on my first try, I am sure you can handle it.
6t6merc
Dec 27, 2013 08:11 PM
Bob Landry
May 10, 2013 07:46 AM
LRSTony
Dec 19, 2010 02:00 PM
mojo79
Nov 22, 2010 01:13 AM
9explorer8
Mar 28, 2004 06:08 PM
