What setting to run
Old Jun 1, 2008 | 10:36 AM
HKusp's Avatar
HKusp
Mine (and I believe most) stays where I put it.
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Originally Posted by rivrrunner
my tunes reset to 1-stock ,very time i turn off....thought that was normal...so she would have to learn to set for 60 tow or 80e...
Did you ask for it to do this? I think this is the first I've heard of a DP going back to stock on it's own.
Old Jun 1, 2008 | 10:40 AM
rivrrunner's Avatar
rivrrunner
nope... it's kinda handy though as you don't have to worry about startin in 140 smoke when it's cold....
UP_There's Avatar
UP_There
I think it's pretty harsh on the ICP to actually start up in a performance tune....so it's not such a bad thing yours re-sets to stock. I always set mine for stock before I shutoff. Then back up to 80econ after it's warmed up a bit.
Old Jun 1, 2008 | 10:44 AM
rivrrunner's Avatar
rivrrunner
Travis: I usually set it to stock to idle down and lower the egts below 400* but when i forget it cycles by itself to 1-stock
Old Jun 1, 2008 | 10:51 AM
UP_There's Avatar
UP_There
I didn't know that option was available? Did you specifically request from Jody for it to revert to stock? Or did it just start doing it on it's own? I've never heard of that....great idea though!
Old Jun 1, 2008 | 10:53 AM
rivrrunner's Avatar
rivrrunner
did not request....i ordered mine the day Jody got back from Smokin, maybe it's sumpin he's changed...........
Old Jun 1, 2008 | 10:58 AM
UP_There's Avatar
UP_There
Not sure if it's just a new thing, I haven't heard about it. I got mine actually more recent then you did, but I got it through Dennis at ITP. He burns all of Jody's files the same though. Maybe I'll ask him about it when I do my first re-burn
Old Jun 1, 2008 | 11:08 AM
PaysonPSD's Avatar
PaysonPSD
Travis,
Let us know if the revert to stock tune is available. I'd drive down to Glendale just to have it done.
Old Jun 1, 2008 | 12:10 PM
jdecker88's Avatar
jdecker88
I got mine at Smokin and I just got it reflashed a couple of weeks ago and mine doesn't do that, but I always start my truck in stock. Jason nearly 5 dollar a gallon fuel doesn't stop you from blown smoke does it .
Old Jun 1, 2008 | 12:12 PM
ron's power stroke's Avatar
ron's power stroke
you guy's that have the auto set back to stock..do you by chance have gauge pod switch???
Old Jun 1, 2008 | 01:12 PM
UP_There's Avatar
UP_There
Ron.....I have the gauge pod switch, but it doesn't revert to stock......YET. Going to email Dennis right now and see if he can do it or not. I'll let you guys know!
Old Jun 1, 2008 | 01:18 PM
  #28
ron's power stroke
maybe try this??? mine will stay in last tune..but i dont mind... i like to shut down at night in stock..it lets the injectors un load a little and level out....
File Type: pdf
  #29
Markadeck's Avatar
Markadeck
I ran an 80 HP Superchips Gold for 8 years with no ill effects. In fact I may get the best mpg of any member here. Truck is completely trouble free if you discount 2 starters, 2 alternators, and 2 transmissions over all these years and miles. I have absolutely zero oil leaks. So, I think if you guys are looking for someway to spend 45 bucks on another tune, pick something more fun than reverting to stock.
Old Jun 1, 2008 | 01:25 PM
  #30
rivrrunner's Avatar
rivrrunner
yes gauge switch...if this isn't normal then i need to check w/ Jody
