68 Bronco Restoration Project
Thanks,
whew.. i'm out breath..
good luck
You also need to absolutely honest about what you can and can't do on your own, and what kind of money you want to sink into a truck. So you don't end up like this:
Ebay is okay if you are able to drop 50k in this thing for fun and won't miss it, or if you can build cars from scratch and want to snag something cheap. Otherwise look before you leap.
I'd first go and round up support troops, local shops, etc, that you might need to complete the project and get and idea of costs.
When you look at these things.... bring a magnet with you.
If you are already a veteran of old cars, here are some things unique to old Broncos:
68 is bad year because stock is no power steering or brakes, and I think vac wipers were not offered yet.
The Bronco body is poorly designed with seamed quarters and is prone to rusting into oblivion.
Power steering is somewhat rare and expensive. The Bronco box is basically like a rare corvette box and only broncos came with them. You can get parts, or send them to be rebuilt at places like straight line steering in CA, but if you buy a kit to convert it will be a grand or more to do in parts.
The Boxed frames are pretty good and don't usually rust through.
Broncos are like a box of chocolates, you never know what you will get. Like a 67 title with a 74 Bronco. Many people have canibalized them over the years for trail use, etc, and many have already beed upgraded.
Unless you are a ace mechanic, before you buy, get a shop to do a leakdown test, and a vaccum test, see the fluids in the diffs, etc and give you an opinion.
As long as you are brutally honest about what you can and cant do and what you are looking at you will be in for some fun
As TomThrall mentioned, the biggest issue in buying one is rust. Everything else can be rebuilt or replaced easily. Rust repair and major panel replacement takes a lot of hours and a bit of know-how and some special tools.
Jason
