Surging at idle
Old May 30, 2008 | 09:53 AM
keithredfirebird's Avatar
keithredfirebird
Surging at idle
I have a 1973 F100 2wd c4 trans with a 2 barrel carb. Truck had set for a few months when I started driving it again it surges at idle when I stop. The truck is running rich. The motor was completely rebuilt 8,000 miles carb was rebuilt by a rebuild center. Distributor was replaced with an electronic accel. I checked for a vacuum leak but could not find a leak. I have an electric choke and it does open when the engine warms. I replaced the egr valve late last year. In the past I have had a problem with spacer to manifold gasket burning a hole causing a leak. I find this to happen when I am doing a lot of highway driving.
Old May 30, 2008 | 11:07 AM
OldMetal's Avatar
OldMetal
Did you check along where the intake bolts to the heads for leaks?
Old May 30, 2008 | 11:37 AM
LxMan1's Avatar
LxMan1
Look for gas dripping down into the barrels when idling. You may have a small piece of debris in the needle and seat.
Old May 30, 2008 | 12:17 PM
beartracks's Avatar
beartracks
The EGR "spacer" manifold under the carb is famous for warping, clogging and burning through. Causes eratic vacuum leak problems.
Old May 30, 2008 | 01:10 PM
keithredfirebird
(Did you check along where the intake bolts to the heads for leaks?)
Yes I checked all the manifold bolts carb bolts and vacuum line I even checked the trans modulation for a vacuum leak
(Look for gas dripping down into the barrels when idling. You may have a small piece of debris in the needle and seat.)
Great idea I will check it when I get home
(The EGR "spacer" manifold under the carb is famous for warping, clogging and burning through. Causes eratic vacuum leak problems.)
Are these still available or do I need to look for a used one.
Thanks for the great suggestions
Old May 31, 2008 | 07:12 AM
keithredfirebird
I checked for gas dripping and saw none.
I also checked my vacuum it is as high as 19" but drops to 15".
I checked the distributor cap and it looks good.
Any new ideas out there
Old Feb 24, 2011 | 03:03 PM
wendtr's Avatar
wendtr
I know this an old thread, did you ever find out the problem?
twoballsleft
Jan 8, 2022 07:32 PM
nofx guy
15
Aug 22, 2012 07:37 PM
RANGER589
18
Jun 3, 2011 10:03 AM
bbarbour
Aug 13, 2004 12:44 PM
ih8ford
Jul 3, 2004 09:49 PM
