are all flywheels the same?
Old May 29, 2008 | 11:18 PM
jgheid's Avatar
jgheid
Are all flywheels diamaters the same for all FE's. Is there a diference in car and truck flywheels? I got a clutch kit from NAPA and they said the book and computer called for a 12" clutch. but the pressoir plate was to big for the flywheel I got that I was told was off a 71 f350 FE 390. I brought home the (smaller engine) kit that fit the flywheel. Is NAPA wrong, the book said the 390 400 429 460 were all the same.I told the guy that the 390 should not be part of that list.
Old May 30, 2008 | 12:25 AM
Redmanbob's Avatar
Redmanbob
No idea but Bill(NumberDummy) can probably dial this one in a a second flat. Check in on the post I'm sure he or someone else will be along to help out. BOL
Old May 30, 2008 | 01:32 AM
Bear 45/70's Avatar
Bear 45/70
There are different flywheels for different sized clutches plus the 428s and 410s use and external balanced flywheel (off set balance) while the rest are all balanced straight up.
Old May 30, 2008 | 01:59 AM
Hypoid's Avatar
Hypoid
According to some here, the flywheel will interchange between engine families. No one has called BS on it yet, so we'll see what happens with that.
Like Bear said, they are drilled for the different clutch diameters. This I do know firsthand. Also, what Bear said about the external balance stuff! It's special enough that you'd only buy it if you want it, or nobody notices it's different.
The only other thing I can add is a year break between (I think) '64 and '65. The tooth count is different between early and late flywheels/flex plates. From your info this is not a concern.
Old May 30, 2008 | 03:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
352/360/390 flywheels
There's no such thing as a 12" clutch used on any 390 engine, even the HiPo's.
Ask that genius at NAPA to look in his book/computer again. He (or his sources are) confusing the 390 FE engine with the 330 FT engine which uses a 12" clutch: 1964/78.
C5AZ-6375-L .. 390 Flywheel / Marked: C5AE-6380-K / (6) 5/16"-18 pressure plate attaching holes on a 12 7/8" bolt circle / Uses an 11 1/2" clutch.
Fits: 1968/76 F100/350 & 1965/71 passenger cars.
C5AZ-6375-K .. 352/360 Flywheel / Marked: C5AE-6380-J / (6) 5/16" -18 pressure plate attaching holes on a 12 3/8" bolt circle / Uses an 11" clutch.
Fits 1965/67 F100/350 (352) / 1968/76 F100/350 (360).
Fits: 1965/67 Galaxie/LTD (352).
C5AZ-6384-A .. Flywheel Ring Gear-184 teeth / Fits them all, 1965/76 352/360/390.
A 352/360 flywheel will work on a 390 and vice versa.
The only difference is the diameter of the pressure plates bolt circle.
For y'all's information:
C5AZ-6375-D .. Flexplate: Fits 1965/76 F100/350 & 1965/71 passenger cars with 352/360/390's with a C6 or C-O-M.
Old May 30, 2008 | 12:26 PM
jgheid's Avatar
jgheid
Thanks Bill that's what I wanted to hear! So as long as the clutch kit fits the FE flywheel I shouldn't have any problems bolting the engine and trans together? Also is there a spacer between the bell and engine? If there is do I need halve to use it?
Old May 30, 2008 | 12:32 PM
Bear 45/70's Avatar
Bear 45/70
There is a steel plate that fits between the block and the flywheel. I've never not used one so don't know if you can cheat and leave it off.
Old May 30, 2008 | 12:45 PM
NumberDummy
C3AZ-7007-F .. Plate-Engine-Rear Obsolete (C3AZ-7007-F replaced C3AZ-7007-D & E)
Fits FE engines with a manual transmission: 1965/76 F100/350 / 1963/71 passenger cars
No Ford dealer has one, Green Sales' and Dennis Carpenters NOS parts websites don't show one either.
Junkyard only item.
Old May 30, 2008 | 04:34 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Or ebay. There are 2 kinds of block plates. Thru 68 the FE's used cup plugs to plug the lifter galleys and sit somewhat flush. The plates have only the round hole cut out for the cam plug. 69 and later FE's used threaded plugs that stick out a bit and these plates have 3 holes for the threaded plugs in the lifter galleys but have no cutout for the cam plug. I've had some plates that had both cam plug hole and lifter galley plug holes that were possibly a generic service item?? Anyway if your block has the threaded plugs you can use an earlier plate and just drill the three holes needed for the plug clearnace. I used to think the plates without the three holes were for solid lifter blocks where the lifter passages are not drilled and plugged. But I was corrected and told what's posted which makes sense somewhat I suppose. Either way you need the plate and they are easy to find. It's a $20 item not the crazy money some ask.
Old May 31, 2008 | 11:12 AM
Alvin in AZ's Avatar
Alvin in AZ
According to my younger son, leaving off that plate (spacer) was what was causing a terrible sound from the starter on a (guy we know) Ford pickup. They were ready to stab the transmission when my son mentioned the plate... "don't need it" said the owner. LOL :)
Alvin in AZ
Old May 31, 2008 | 11:23 AM
NumberDummy
Don't wanna get into a p!ssing contest....one a my finest attributes or detriments-depending on how you look at it.
The 1965/72 car // 1965/72 & 1973/79 truck parts catalogs show exactly one plate, this one: C3AZ-7007-F.
The 1960/64 car catalog shows three, the first two (C3AZ-7007-D or E) were replaced by the third, same # I just typed above.
Could it be that the two plates you've had experience with been in fact one of the two early ones and the late one?
Lotta parts swapping around since day one, and there's no numbers on these plates...my guess is...that is exactly what happened.
Old May 31, 2008 | 12:30 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
I dunno Bill? Never really paid much attention to them before. I'd certainly take your word on it knowing the real facts. Your right with no numbers stamped on any of them it's hard to tell what's what and where it came from. I was hoping you'd chime in and shed some light on the subject. Interesting facts that's for sure.
Old May 31, 2008 | 12:52 PM
Alvin in AZ
Doesn't look like I'll be taking my bell housing off anytime soon. :)
(since I put that 6303 sealed ball bearing in the crankshaft!:)
Used-to it was an every 25k mile project! :/
Anyway, I might be losing my little mind betting with Bill. :/
...but I'd bet money there are numbers on my spacer-plate. :)
Since it's Bill, I'd better not go more than a dollar? ;)
Alvin in AZ
PS- Of course we are talking about a Ford part here...
Like my Chevy-buddies used-to tell me...
"Ford never learned how to make the same part twice ;)"
Old May 31, 2008 | 01:38 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Engine/Transmission Spacer Plate Identification
Old Jun 4, 2008 | 11:55 PM
orich's Avatar
orich
Had a 1961 390 with 12'' clutch, larger tranny bell housing over 184 teeth old style stater think changed over to 11.5 clutch in 63 or 64 my 2cents
orich
chris17453
Jan 3, 2016 10:08 AM
lkfldredneck
Sep 6, 2015 08:11 PM
DaytonaTunnel
Feb 9, 2010 10:32 PM
MR_J_DAHMER
Nov 29, 2005 12:16 PM
jackslater
May 10, 2005 11:01 PM
