Header Panel
Old May 29, 2008 | 06:35 PM
Medic 66's Avatar
Medic 66
Lightbulb Header Panel
Everyone...I am getting together things to do the new 2005 front end swap out. First question I have is this....
The header panel that is in my 1999....is it made of plastic? I see a piece of black plastic that runs from side to side that the head light plastics is screwed into. It is right behind my grille and right under that floppy plastic covering that is on top by the jack tools.
Is this what my header panel is?
Thanks,
RC
Old May 29, 2008 | 07:10 PM
randomhero1172's Avatar
randomhero1172
I think its made out of a light, cheap, fiber glass type material thats black and i guess could be described as plasticy . I think? Bump - wait for someone who knows more.
Old May 29, 2008 | 07:48 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Yeah the header panel, its what you cut into to do the zoodad. Harnesses the lights and the grille, at both top and bottom. I changed mine out so it wouldn't be a --lf-assed install, wasnt too expensive, and it's only held in by like 8x 8mm bolts.
Old May 30, 2008 | 05:32 PM
Medic 66's Avatar
Medic 66
Thanks everyone.
Is the zoodad all that hard to do? Does it affect running any?
What would I gain by this?
Old May 30, 2008 | 11:09 PM
randomhero1172
No its easy - Took me all of about 25 min. Just cut a hole in the correct area leading to the air intake. No proven gains but im sure it delivers much more cold air then the stock setup. Also - rain or snow will not enter and affect the filter element at all. Its a pretty neat little mod. Try it out with a 6637 and its killer
Old May 30, 2008 | 11:37 PM
PowerstrokeJunkie
I cut the zoodad into my 07 header panel before i installed it. Just used a die grinder with a steel cutting wheel, then smoothed the edges. Air it down and it's already done.
