How to Change Throttle Position Sensor
Old May 29, 2008 | 06:12 PM
Aggie05's Avatar
Aggie05
92 ranger, 2.3 ltr TPS is located on the back side of engine right by EGR clusterf*#$. The phillips head screw is behind part of the intake that the egr connects to. Whats the easiest way to change loosen intake or take of throttle body?
Not designed to be easy this truck!
Old May 29, 2008 | 08:30 PM
98range's Avatar
98range
Put a #2 phillips bit in a 1/4" ratchset drive with an extension and unscrew it. Tough but it comes out.
Old May 30, 2008 | 08:09 AM
Aggie05's Avatar
Aggie05
I had to end up taking off TB. IT was worth it b/c i found a vacuum hose connection that was cracked, it runs to the canister on front of grill to underside of TB. Replaced that and TPS and truck was much smoother at idle. Now to get my temp sensors or thermostat replaced and i should be idle even smoother.
Old May 30, 2008 | 08:49 AM
jimdandy's Avatar
jimdandy
Aggie05, heres a heads up for ya. If you take your A&M diploma and lay it on your dashboard, you are entitled to use handicapped parking. Don't know if you knew that or not. jd
I do hope you have a sense of humor....... jd
Old May 30, 2008 | 10:52 AM
Aggie05's Avatar
Aggie05
Yeah well i guess it beats a tu diploma, not sure what those double for.
Toilet paper?
I dont think you can go to A&M and live in TX and not have a sense of humor.
Old May 30, 2008 | 12:24 PM
Aggie05's Avatar
Aggie05
One more thing to note if anybody is taking of TB is if you take off air tube you can reach lower bolts of TB from underneath with a socket extension, think it was metric 8 socket.
DarrellinCeres
Modular V10 (6.8l)
Oct 18, 2016 12:31 PM
njtinman2
32
Oct 16, 2014 01:16 PM
TheDuke
Sep 9, 2014 01:13 PM
Crewcabber
Jul 6, 2014 06:32 PM
lovemyexpy
19
Oct 29, 2010 04:12 PM
