Sponsored by: Innova
Dimmer wire???
Old Dec 31, 2002 | 12:58 AM
RanDawg's Avatar
RanDawg
Dimmer wire???
Old Dec 31, 2002 | 02:44 PM
prodigy's Avatar
prodigy
Dimmer wire???
Yes. I have a orange wire in my 95 ranger which i belive is a Dimmer wire for the brightness of the factory radio. My new cd player doesn't have a place to put in the dimmer and i was wondering if it would hurt anything to just tape this wire up and unconnected. I have been told that sometimes if the wire isn't hooked up the dash lights night not work right. IF this is true what do i do with this wire. thanks
Old Dec 31, 2002 | 02:52 PM
RanDawg's Avatar
RanDawg
Dimmer wire???
First, find out if the dash lights don't work properly. I doubt this will be an issue. Just tape the wire and tuck it.
If for some reason it is and issue (can't see why), use a light bulb and hook it up to the wire. That will give the dimmer something to dim.
Old Jan 1, 2003 | 02:07 PM
CobraXP's Avatar
CobraXP
Dimmer wire???
Prodigy - have you already cut the factory plugs out of the dash? If not, I would go to the local stereo shop and buy the adapters to wire your new radio to - then plug it into the factory plugs in the dash. Makes for a much easier install, plus if you ever want to go back with the factory radio, you can just unplug your radio and stick the factory back in...
Old Jan 1, 2003 | 11:25 PM
Crash08's Avatar
Crash08
Dimmer wire???
Dont worry about the wire tape it up.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Roachfood
Mar 11, 2002 10:21 PM
