2.3 block differences?
Old May 29, 2008 | 07:55 AM
fairlaniac's Avatar
fairlaniac
I have an '89 Ranger 2.3 4 cylinder. Are there many if any differences in short blocks? I have access to a few free used engines, mostly from '79-up Mustangs (so I'm told). I want to grab one and rebuild it for my '89 Ranger. Any history on short block changes over the years?
Thanks,
Old Jun 16, 2008 | 11:06 PM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Check out The Ranger Station - Your Ultimate Ranger Resource they have a section on the 2.3 blocks and the differences between years. I haven't read up on them in months, but I thik the blocks are pretty much all the same with only minor differences. but check them out just to be safe.
Old Jun 19, 2008 | 07:13 PM
Old Rob's Avatar
Old Rob
Thanks,
Try powerbyace.com email to thier tech line.
Old Jul 14, 2008 | 11:25 PM
f_ford_custom's Avatar
f_ford_custom
?89? DIS, right? Dual plug? you'll have to look for a ?88? or later block. Cam/crank sensor, dizzy hole, ?balancer shaft-its in a 96?. if you have to go to a different block, try a 83-(86 for Mustang-88 for T-bird) Turbo EFI 2.3L, get 5.0 power when you stomp on it, 2.3l economy when you don't.
Too bad PAs soo far away, looking @ 86 2.3l stang, 2bbl, EECIII/4spd OD, can't hardly beat $200 and it runs and drives well.
Rangerr86
1983 - 2012 Ranger & B-Series
Dec 5, 2014 01:03 AM
Plowboy34
Jan 14, 2014 06:34 PM
meck1
4 Cylinder Engines
Aug 16, 2007 02:42 PM
gUiTo1969
Mar 17, 2004 05:07 PM
Ranger_Eric
Sep 26, 2002 03:53 PM
