Hey long time no see. I pull front clip and bed . Unplug everything and un bolt jack up and slide what ever under cab (I use 4 2x10 2 on front and 2 back ) and use block props what ever to prop up. . Work cab up till high enough to clear frame on back roll frame out from under cab .
I have dont it the this way several times. Just make sure its stable when on props good luck
Only problem I might have with that idea is the truck is so tall that I don't know what I could use to lift the bed up high enough even with boards sticking out the sides.
55 gallon drums with several layer 2x or 6x6 between then to build up hight . Then the pieces (2x10 ) ac crossed frame to other side. Scary but it works
