intake manifold
Old May 28, 2008 | 01:00 PM
9299Fords's Avatar
9299Fords
intake manifold
I'm looking for an intake for a 390 I'm putting together and have run into one advertised as "Ford 390 GT S code 4V intake-C6AE casting" for $75. Is this one I should pick up or should I keep looking? I can't find it listed in the books I have. Books aren't that good.
Old May 28, 2008 | 02:10 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
It's more or less your basic FE intake. Also used on most cars and trucks besides the GT 390 engines. $75 is a bit much. These are $30-40 intakes at the PYP yards. It's about the same as the Edel Performer except it's cast iron and pretty heavy.
Old May 28, 2008 | 02:27 PM
9299Fords's Avatar
9299Fords
Thanks. I had heard that the "S" code was a better than average intake. I guess I'll pass on it.
Old May 28, 2008 | 02:35 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You don't have the right ones.
Parts book sez:
C6AZ-9424-N .. 4V Intake Manifold
Fits: 1966/67 Galaxie/LTD 390/428 exc Police Cruiser / 1966/67 T-Bird 390/428 / 1967 Mustang 390
How many do you want? There's a ton of them around here at the U-pull yards, 10-20 bucks each.
Old May 28, 2008 | 02:40 PM
monsterbaby's Avatar
monsterbaby
Hey Bill do you have the numbers for the PI or GT intakes so IF he runs across one he knows?
Old May 28, 2008 | 04:38 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
The C7AE-9425-F and C6AE-9425-H are 2 of the more common PI intakes out there. These are in the $700-800 and up range in nice shape. Blue Thunder sells a nice repop PI for around $500. There are no real GT390 intakes persay. They are the same S intakes used on other FE's. I'm sure Bill can tell you the part numbers on the PI intakes. Those I listed are the casting number found on the intake itself.
Old May 28, 2008 | 10:06 PM
9299Fords's Avatar
9299Fords
Thanks! I know where there's a C7AE. I better be about finding out the rest of the number.
I checked with the owner of the C6AE and it is a C6AE-9425-G
Old May 29, 2008 | 04:27 PM
9299Fords's Avatar
9299Fords
Close but no cigar. One of those hand grenades and horseshoes things.
available now pretty cheap...
C7AE-9425-E and C6AE-9425-G
Old May 29, 2008 | 05:30 PM
80broncoman's Avatar
80broncoman
Because of it weight an iron FE intake Is probibly the most effective anti wheelie device made by Ford. (in a front engine car)
Old May 29, 2008 | 06:25 PM
9299Fords's Avatar
9299Fords
I'll put in a light transmission. That will counter for the intake weight and put the weight where I need it. Still light, no wheelies, better time.
BroncoBilt
1978 - 1996 Big Bronco
Jan 15, 2015 06:03 PM
Hammell
Jun 28, 2014 01:17 AM
110
Nov 1, 2013 08:06 AM
dabeast250
Sep 3, 2004 08:37 AM
Damon Dimick
Jun 13, 2003 07:05 PM
