Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
black and decker trimmer
Old May 28, 2008 | 12:45 PM
nomadic's Avatar
nomadic
This forum is so helpful....I thought someone else might have encountered \this problem....I have a nine inch black and decker cordless trimmer. It works just fine for the size of my yard....but I have encountered a problem....The cord finally ran out on it....I took the bottom off and decided to replace the cord, as I was told that you did not have to buy a whole new spool. Unfortunately however, it does not rotate most of the time.....DID I LOSE a spring or something else. THERE is a little white arm under the spool that has a red dot on it I BELIEVE.....I have looked at it several times, but I am not exactly mechanically inclined....HELP IF YOU CAN....NOMADIC
Old May 28, 2008 | 05:19 PM
lenny1carl's Avatar
lenny1carl
my B&D has a spring in it..i believe the white tab you speak of is so the spool can't slip backwards
Old Jun 3, 2008 | 01:08 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Moved from GC.
spikedog
Aug 26, 2009 07:41 PM
aerocolorado
16
Sep 20, 2008 10:17 AM
MikeB 88
Jul 29, 2005 05:50 PM
T Bone 50 51
Sep 27, 2002 05:56 PM
