Adding amp and sub to factory system
HELP! Basically, what's the best way for me to add an amp and sub to the factory system?
And even if you could, it would hardly be a sound quality improvement...
You'd have the signal coming from the head unit, going through the first amplifier, through all it's circuitry, getting amplified by what amounts to a cheap amp (I'd have my suspicions about it's linearity and response), getting stepped down again, going through another amplifier and all it's circuitry...
The chances of getting a clean signal (sound) out of the second amp would be greatly reduced...
And in the event that you didn't get a clean sound... how would you go about determining why it didn't sound good.. which is the culprit?
To properly add an aftermarket amp in this scenario requires one of two approaches:
1) Replace the factory head unit in addition to adding the amp. In doing this, you can run an RCA cable to your aftermarket amp, unobstructed. Be careful however, not to use the factory wiring to the speakers (it's common to run your speaker leads from the amp to the dash, and make your connections to the door speakers there), unless you have confirmed 100% that the "premium" system amp is inside your head unit, and not remotely mounted elsewhere... or you could recreate the same problem all over again!
2) Use an adapter meant for this scenario. I have installed two PAC OEM-1 devices in the past couple years, and they seem to work very well, they are avaialble here, or anywhere that sells PAC:
http://www.tune-town.com/Cars/stuff/pac_oem1.htm
What this device is, is a 'black box' that allows you to either retain the factory head unit and add aftermarket amplifiers... Or allows you to add an aftermarket head unit while retaining your "premium" stereo, depending on which cables you buy for it.
In addition to this little 'black box' you need to buy two of three types of cables made for it, some of them specific to your particular car:
A-type cable: Used to interface aftermarket stereo to 'black box', to add a head unit to a factory "premium" system
B-type cable: Used to interface 'black box' with your car's factory wire harness that plugs into your stock head unit, when replacing the head unit. (AMP-RCA cable is used when adding and/or bypassing aftermarket amplifiers, however.
C-type cable: Used to interface 'black box' with your car's factory wire harness that plugs into your stock head unit when adding and/or bypassing aftermarket amplifiers.
Using this little device is a very easy thing...
Plug your AMP-RCA cable and appropriate C-cable into the OEM-1 'black box'..
Unplug the factory harness from the head unit..
Plug it into the female plug on the C-cable..
Plug the male plug of the C-cable back into your head unit (restoring that connection)...
Plug in your RCA's, use the potentiometers to make your gain adjustments, and you are in business!
I suggest the 2nd approach.
Andrew
www.subbox.net
