General Diesel Discussion
Do tractors have gp's?
Old May 29, 2008 | 04:34 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
The New Holland Boomers have glow plugs. They start just like our trucks, turn the key on and waite till the light turns off to start. I have the 5325 John Deere and I have glow plugs for cold starts in the winter. Push the key in to start the glow plugs.
Old May 30, 2008 | 07:48 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
In my younger years I ran a D8 dozer which had a pony motor to start the main engine.
Old May 30, 2008 | 08:35 PM
rbaker6336's Avatar
rbaker6336
yep the first one I ran didn't even have electric start on the pony motor
think in '64 ot '65 they put direct start on the smaller motors but D8s and D9s didn't get eletric start til in the '70s
now operators bitch if they don't have A/C
Old May 30, 2008 | 08:39 PM
bigredtruckmi
Veteran: Navy
Wonder what they would do without rollover protection, ac, etc. AHH back to bare skin and a ball cap.
Old May 30, 2008 | 09:09 PM
stormyrider's Avatar
stormyrider
IH uses precombustion chambers in a lot of thier engines and these require glow plugs to start. Cat uses a nichrome wire heater in the air intake to heat incoming air. Some of the engines I have driven on older trucks had glow plugs in them, most do not. Now a days a more common feature is a block heater you plug in when at home and when away from home if they have a sleeper with a tripac unit, it is water cooled tied into the main engines block and keeps the main engine warm while suppling heat/cooling and power to the sleeper. You can also have a starting fluid dispenser that is triggered from the cab if you don't have glow plugs or air heaters.
Old May 30, 2008 | 09:23 PM
rbaker6336's Avatar
rbaker6336
the earlier Cats had precombustion chambers think the V8s were the first to do away with them
Old May 31, 2008 | 09:44 AM
tjc transport's Avatar
tjc transport
i ain't rite
nothing like an old cat D-9 with a hand crank pony motor, johnson bar clutch, and cable blade to differentiate the men from the mice.
ok ya young pups. go ahead and look pony motor, johnson bar and cable blade up in your wikpedia, and see what ya come up with!!
Old May 31, 2008 | 07:02 PM
FARM69's Avatar
FARM69
We used to call them trolley bars... Anyways, Johnson bars are still pretty common if your around big rigs.
Old May 31, 2008 | 07:09 PM
rbaker6336's Avatar
rbaker6336
the parts on a caterpillar machine refered to as johnson are named after a caterpillar engineer,can't remember fist name but last was johnson
he designed much of cat equipment including their selfloading scraper ie 631J etc, 6=scraper 31 =yardage J=johnson or self loading
Old May 31, 2008 | 07:42 PM
FARM69's Avatar
FARM69
Interesting infor rbaker. It kind of makes you wonder why and how they come up with the names and such.
Old May 31, 2008 | 07:49 PM
rbaker6336's Avatar
rbaker6336
just a little more or less useless info you pick up spending entirely too many years around the stuff
Old Jun 2, 2008 | 01:50 AM
69-highboy's Avatar
69-highboy
Those old corn binders were prone to cracking heads. Run it out of fuel once, and the head cracked. I put many an hour on an old TD18, and except for the magneto I remember them being fairly reliable. The injector pop-off pressure was insanely low too -something like 500-1000 psi.
I put a lot of hours on an old D-8 and a 5020 John Deere. I guess that explains why I can't hear worth a hoot today.
Old Jun 2, 2008 | 10:24 AM
  #28
bradcollison's Avatar
bradcollison
Actually that is an intake grid heater. I don't know of any newer John Deere tractors that have glow plugs.
That is a "cold weather" option for my tractor, which I don't have. The John Deere dealer did install a block heater though. That's all I need when really cold out. I run a synthetic 5W-40 oil too.
I probably have the same engine (family) as you.
3cyl Powertech turbo diesel 64HP.
Old Jun 2, 2008 | 11:12 AM
  #29
miller_feed
OK. I never have to use the heater so I thought they were glow plugs. Mine is the new 5 cyl turbo, 68 HP.
EDIT: I have a pic in my gallery of the tractor on the trailer.
Old Jun 3, 2008 | 08:15 AM
  #30
deereman4020's Avatar
deereman4020
Originally Posted by 85Diesel_F250
I'm doing a demonstration on diesel tractor engines tomorrow. I'm in 4h. I started thinking......so do tractors have glow plugs? I'm sure the newer one's do but idk. Don't want to give a demo w/false info.
it depends on the brand of tractors John Deeres have glow plugs and block heaters. Cases dont usually have glow plugs, newer New Hollands (and fords) im not sure about. Cases dont have glow plugs because they usually start nicely with out them in the winter down to -10 or -20 degrees after that you need to plug their block heaters in. trust me i live on a wisconsin dairy farm and we have John Deeres and Cases.
