HELP 93 ford ranger blinkers dont work
i have a 1993 ford ranger and the blinkers wont work.. i have checked the flasher box in the fuse panel or what ever its called and its fine.. i tested it and it works... the 4 way flashers work but the blinkers just stopped working.. i have checked al the fuses too HELPPPPPPPP!!! thanks...
Wrong section, This section is for the 2009 F150
Here is the ranger section
Ranger & B-Series - Ford Truck Enthusiasts Forums
Believe it or not but it can also be the towing harness is bad. Unplug the lasso from the main by the spare tire rack and see what happens. If you need a new one Rural King and maybe some other farm supply stores sell them for around $20.
I had one go bad in mine and it affected the cruise control and signals.
Good luck and welcome aboard!
Yup, I have a tilt wheel! After your explaining that I would figure it is definitely in the column.
If you haven't already got one and can afford one get a manual from Ford, but they're a bit pricey. The next step down is a hayne's manual's which are better than chiltons, but that's still not saying much.
Good luck!
Good luck!
will32_
24
09-28-2014 10:18 PM
