Question
Old May 27, 2008 | 07:36 PM
jeremiah302's Avatar
jeremiah302
Question
I was wondering if the side mount gas tank off of a 88 F-150 will mount on a 95 F-150 4x4 and work with the same fuel pump that is in the tank off the 88? they both have the V-8 302's in them, the only reason I am asking is b/c the 95 does not have the side tank on it b/c it was removed for some reason. If any one could give me some insight on weather or not this will work it would be much appreciated. I am scrapping the 88 out this week b/c I don't need it now. The only thing I am saving from it is the head lights, mirrors, motor and tranny, and the windshield and tail lights. So if any one needs any of those parts or something else let me know before Friday morning, and if your are close enough I can get them to you.
Old May 27, 2008 | 08:19 PM
bluesman2333's Avatar
bluesman2333
Not even close. Wrong pump, wrong gallons IIRC, wrong mounting too, again IIRC.
Old May 27, 2008 | 08:54 PM
jeremiah302
hmm ok ty, but why does that model year (95) have 2 different types of tanks as the side tank? one was a 16 gallon and the other was a 19 gallon? Now where or how do I find out which tank goes there?
Old May 27, 2008 | 08:58 PM
EPNCSU2006's Avatar
EPNCSU2006
the regular cab short bed configuration used the small tanks. The 95 uses a high pressure in-tank pump with built-in switching valves, while the 88 uses a low-pressure in-tank pump without built-in switching capability.
Old May 27, 2008 | 09:01 PM
jeremiah302
ok, but both of mine long beds, oh well quess I'll just have to buy a new tank and fuel pump for it one day
Old May 28, 2008 | 04:53 AM
EPNCSU2006's Avatar
EPNCSU2006
If you could find a tank from both years, you could compare the opening in the top to see if they match. You could also go to the parts store and compare a fuel sending unit from each of those years to see if they attach the same.
choate
Jun 7, 2014 07:05 PM
The Weasel
Sep 19, 2012 07:12 PM
Damstr8
Jun 11, 2009 08:46 PM
strokin'_tatsch
17
Jan 28, 2009 11:00 PM
fordzrule
Oct 16, 2003 07:56 AM
