Help coolant neck bolts!
Old May 28, 2008 | 09:04 PM
megawatt00's Avatar
megawatt00
Originally Posted by Benny2002
Nice jamin, im glad for you things are still busy. Which license did you get? Im taking my journeymans test finally middle of next month. Then i might call the union shop up in tampa/st pete and see about starting in their 5th year. We'll see
The bolt situation went just as i thought for now, the old bolt was worked about three quarters of the way out and i threaded in a shorter version of the same thread pattern. It held today without leaking with you know florida heat about this time of year. I hope it holds for a while but mainly just long enough to where i can have more time to mess with it.
For future reference anyone messing with the water neck:
Spray it with pb blaster, let the engine heat up and cool down all the way, then shoot some more pb and cross your fingers.
Anything other than that and YOU WILL break one of the heads off guaranteed!
Theyre worse than an exhaust manifold bolt on an aircooled VW.LOL
Jamin congrats on the test, not alot of people can appreciate the two big electrical exams are but i do, nice work!
Benny good luck on your test! Wait until you do the masters it is tough, but worth it.
Jamin Congrats on passing! I'm happy for you!
Old May 28, 2008 | 09:08 PM
totin_tools's Avatar
totin_tools
Well good thing you got the bolts to work. I know some on here have gone and bought the bolts at the IH dealer. Might want to check around and see if you can find the right ones, especially when it really gets hot down there in a month. I took the Journeyman Electrician test and then you have to take a seperate Wa part. Passed NEC with 83 and Wa w/ 88. So now I can go to several places after I wait the one year to recipricate it. Also have the Ca JW license and two in Fl. Good luck on taking the test and if you need some study materials let me know, I might be able to help.
Old May 28, 2008 | 09:14 PM
totin_tools
Thanks, Jim
Old May 28, 2008 | 09:29 PM
Benny2002's Avatar
Benny2002
I might have to hit you up for them if i dont pass the first time, i think im going to be good though, didnt get below an 86 on the practice tests all 4th year of school, we'll see.
I will keep you posted, and maybe need some rep points at the union here
Old May 28, 2008 | 09:32 PM
totin_tools
Ok just let me know. Is the test on the 05 or 02 code book? I have both tabbed and highlighted. It helps trust me. Good luck.
Old May 31, 2008 | 07:14 AM
Benny2002's Avatar
Benny2002
The bolts are an international part number about 8 dollars a piece, but you can get similar at advanced auto parts they are just a little long but go through the housing anyway.
Grade 8 M-6 1x30mm
white dually 2001
Large Truck
Apr 29, 2014 05:07 PM
KRDiesel
Nov 23, 2012 08:56 PM
robjs111
1978 - 1996 Big Bronco
Apr 2, 2012 01:19 PM
gthbryce
Feb 12, 2010 06:55 PM
