General Automotive Discussion
87 BMW 325 question
Old May 27, 2008 | 05:06 PM
7283-F250's Avatar
7283-F250
87 BMW 325 question
I have a 87 325I with a weird problem.
It kills the battery if is sits for more than a few days. It has a brand new battery and the problem only started recently.
My main question is about the LED bar of lights on the center of the dash. Does anyone know the significants of them and/or there meaning. There is typically one of them on when the car is off but now there are 2 of them on.
Thanks
Old May 27, 2008 | 05:24 PM
jroehl's Avatar
jroehl
Here's how to start tracking down battery leaks. Take off your negative battery cable and attach an ammeter between the battery terminal and the cable. If your battery is being drained, you should see an amperage draw, perhaps more than about 0.1A. Whatever it is, write it down. Now, find your fuse panel and start pulling fuses one by one. After each one, check the ammeter to see if the amperage dropped. Whichever circuit causes the biggest drop in amp draw--that's your likely culprit, and that's where you start looking.
Jason
Old May 27, 2008 | 08:19 PM
sglaine's Avatar
sglaine
Posting Legend
I heard that plugs could cost $40 a piece
Old May 28, 2008 | 07:14 AM
Lazy K's Avatar
Lazy K
Very good advice from jroehl. Also check the alternator for a drain. A freind of mine had a similar problem with an early `90s BMW which turned out to be a small cooling for one of the switches on the dash running after the ign was switched off. Don`t know about the lights on the dash.
Trophy_23
Nov 12, 2016 11:24 AM
hwybee22
Aug 20, 2016 09:10 PM
crazed87bronco
Ford Truck Parts for Sale
Aug 14, 2016 09:50 AM
strickland
2015 - 2020 F150
Aug 1, 2015 02:39 PM
fluknick
21
Feb 13, 2012 06:40 PM
