Anyone running 35x12.5 BFG AT KO2's? I am currently running 325/65/18's on factory wheels. From what I can tell the 35's are basically the same diameter but are a narrower tire. Want to make sure they will fit on my stock 07 before I order them up.
I don't, but I have seen many 35x12.50's on stock wheels with no problems. You will be good to go. They will offer a little more clearance than the 325/65/18's too.
Sometimes it is hard to find a 80psi rated tire in that size. I ended up with a 285/65/20 a 34.5x11.50 tire. Another I considered was the 295/60/20 a 34x12. I want a 80 psi 10ply rated tire that is not quite 12.5 wide.
