Front tank fuel pump
Old May 27, 2008 | 04:10 PM
capecove's Avatar
capecove
Hello folks!
I have a question that I searched the forums regarding and found some good information but nothing exactly like what is happening to me. So, I would love any/all advice you can provide.
I have a 1990 F-150 with a 351, auto transmission, 4x4, etc. When I run off the rear tank I get regular performance and excellent reliability. If I run off the front tank, it responds normally when depressing the throttle up to 30-40% or so but begins to surge and hesitate at anything above that point. As I let off the gas, the hesitation goes away. So, this screams fuel pump to me, but here is the twist:
If I run off the rear tank, the rear tank seems to be filling the front tank? I intentionally siphoned out two 5 gallon cans worth from the front tank pouring it into the rear tank, then drove it using the rear tank for about 30 miles. I felt like the fuel gauge was going down drastically, from 3/4 at the start to just above 1/4 when switching back to the front. Lo and behold, the front was reading full again. Also, the front tank just always seems chock full, even to the point of overflowing when sitting in the sun.
Any advice on what is going on here folks?
Thanks everyone!
Old May 27, 2008 | 04:29 PM
wintremute's Avatar
wintremute
Sounds like 2 things are happening.
A. Front pump is weak
B. Fuel selector valve is failing and pumping gas from rear to front tank.
B can cause A since it is effectively fighting the normal flow of gas. Replace the Fuel selector valve on the frame rail.
Old May 27, 2008 | 06:08 PM
EPNCSU2006's Avatar
EPNCSU2006
1990 should have been the first year for high pressure in-tank pumps, with the switching valves built into each tank's sending unit or fuel delivery module (FDM). If this is the case, the fix will be to replace the front tank fuel delivery module/pump assembly.
Old May 27, 2008 | 06:30 PM
alz's Avatar
alz
As Eric says, replacing the front pump should cure both problems.
Old May 28, 2008 | 10:17 AM
wintremute's Avatar
wintremute
Ah, i see. Mine has the low pressure in-tank pumps and the high pressure one on the frame rail. Sorry for the disinformation.
Old May 28, 2008 | 05:43 PM
capecove's Avatar
capecove
Thanks!
Well, I wish it was better news, but thanks anyhow... A new front fuel pump is in order...
Thanks again!
Old May 28, 2008 | 07:06 PM
acogoff's Avatar
acogoff
If it were mine. I would pull the tank out and check that your screen isn't just full of crud and clean the tank out at the same time if the pump is running there is hope. Get your self a spray can of kroil to loosen up the long rusty tank hold in bolts and the ring on the top of the tank. Kroil is a god send for these jobs.
The fuel transfering from the back to front though is a bad sign. If the check valve can not be cleaned a new front pump assembly is in order.
Old May 28, 2008 | 09:38 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
I disagree. If you go through the trouble of removing the tank and have a few extra bucks, replace the internals while the tank is out. I replaced my front tank as it was leaking from the top and tried to save a few bucks by not replacing the internals while the tank was down and out. One year later, my front pump went out and I had to drop the tank again. If you value your time, take heed. Change your pump, sending unit and do a thorough inspection of your tank.
Tim
