I want to put a 90 302 in my 76 ford. Are the motor mounts the same?
if not can I cut the ones out of the 90? Steel mounts not the rubber pads on the block.
Reason: gramer
I want to put a 90 302 in my 76 ford. are the motor mounts the same?
if not can I cut the ones out of the 90 steel mounts not the rubber pads on the block
No, the motor mount perches (aka stands, brackets) are not the same as the FE perches.
They are the same as a 302 in a 1969/79 F100, 1975/79 F150 & 1977/79 F100/350 with a 351M/400.
351M/400 = 2WD only.
D7TZ-6028-B .. R/Engine Mount Perch (replaced D0TZ-6028-A)
D7TZ-6029-B .. L/Engine Mount Perch (replaced D0TZ-6029-A)
Part numbers shown for reference only, they are no longer available from Ford.
