engine coolant overfill
Old May 26, 2008 | 11:24 PM
dieselsmoker's Avatar
dieselsmoker
my truck is an 06 6.0 with 107000 kms on it and im trying to figure out what is goin on with it. Ive had to fill up the engine coolent overfill 3 times in the last month im wondering where it is going. Plus it is not leaking out cause there is no puddles under my truck so what is going on plz help
Old May 27, 2008 | 12:23 AM
rollerstud98's Avatar
rollerstud98
sounds like you may have yourself a possible egr cooler failure or even the head gaskets, where abouts you from and what all have you done with your truck mod wise?
Old May 27, 2008 | 12:43 AM
brickie's Avatar
brickie
Have a look at the valley on top of the motor and see if it is wet,if its bone dry pull the egr valve and see if the soot is wet or dry.If it is dry I would suspect the head gaskets or injector sleeve next.
Old May 27, 2008 | 01:37 AM
dieselsmoker
i am from brooks alberta canada,all i have done to my truck is a 4 inch magnaflow turboback exhaust
Old May 27, 2008 | 08:59 AM
rollerstud98
Right on, I go camping down by Brooks in the summer, on Lake Newell or whatever it is. I'm from Airdrie, don't know if you know it or not but its just North of Calgary
