Eng Light On
Old May 24, 2008 | 01:32 AM
Culvert's Avatar
Culvert
Eng Light On
Hey Guys,
Truck has been pumping out blue smoke last little while. Only while in Tow/Haul mode and low speed. Mostly stop sign to stop sign in town.
This past wknd however while towing my 28'TT I went to pull out onto the main hwy, truck felt flat/ lack of power, and I looked down at dash and ENG Light was on.
Pulled codes with a friends OBD2 code reader and I got...
P0261, 264, 267, 270, 273, 276, 279, 282.
Before I take it into the dealer can anyone tell me what these codes are and what I can check on the truck.
Cause of BLUE smoke and now the codes?
Thanks.
Old May 24, 2008 | 01:50 AM
doubledee715's Avatar
doubledee715
0261: Injector circuit low cylinder 1
0264: Injector circuit low cylinder 2
0267: injector circuit low cylinder 3
0270: injector circuit low cylinder 4
0273: injector circuit low cylinder 5
0276: injector circuit low cylinder 6
0279: inj circuit low cylinder 7
0282: injector circuit low cylinder 8
what did you run through your truck!?!?! A racoon!?! lol I'm no tech in any way shape or form but if my truck pulled those I would think I needed all new injectors. Get that thing somewhere quick man, good luck.
Old May 27, 2008 | 10:29 AM
Culvert's Avatar
Culvert
Ok, never made it to dealer. Was using the truck this wknd and now the eng light no longer comes on.
Is there any reason why I would have gotten all those codes at once? Bad fuel filter? Bad oil?
Some things I can check rather than take to dealer and have him tell me the codes arent there and need to wait untill it happens again.
Thanks guys.
Old May 27, 2008 | 11:09 AM
labrown's Avatar
labrown
About 2 weeks ago, I got the exact same set of codes on my 05. I was pulling the 5th, at the time. I felt no drivability problems with mine. My CEL also went out the next day, and hasn't returned.
Mine happened as I was starting at night. The 5th was lit up with over a dozen bulbs. I was wondering if this was caused by the batteries getting weaker, and with all the extra load, dropping the voltages below a threshold.
Any thoughts?
Old May 27, 2008 | 12:03 PM
Sarge261's Avatar
Sarge261
I had the same problem with my 06...The dealer un hooked the Banks system, ran it and still had the problem. Turns out that the crossover pipe was leaking/plugged at the rear of the engine. They replaced the crossover pipe, reflashed it, and all has been ok since. Mine was not smoking though.
Sarge
