Overdrive
Old May 28, 2008 | 10:51 PM
Fordy1's Avatar
Fordy1
I am having the same issue only my truck stalls and dies when I come to a stop, I have had my tranny rebuilt by Ford dealer and back again, 9 months later It has happened yet again, odd thing though after work today the light cleared itself and is working as normal again, but I know it wont last. 5 weeks in and out of the shop (Ford Dealer) and $1,800 later no answers, the tech even took a ridealong with me while his computer was hooked up and we got it to go into fail mode, still no definitive answer. VooDoo
Old May 29, 2008 | 07:00 AM
ingman's Avatar
ingman
Searay, Rubber duck know these trucks inside out. I think he has earned the and proven his self. Stick around this forum and you will see for your self.
Good luck.
Old May 29, 2008 | 07:20 AM
MADVAN's Avatar
MADVAN
https://www.ford-trucks.com/forums/7...-question.html
B
Old May 29, 2008 | 04:34 PM
RubberDuck's Avatar
RubberDuck
ingman, I really appreciate the kind words. But I'm not always right. I'm just saying what I would do. I know alot of people don't have access to scanners or places that do. At that point I think it would be worth throwing $25 at it just to see. And I know others will disagree, but that's just my take on it. And these other guys are auto guys as where I am not. And while I do know alot about these trucks, I don't know crap about auto trannys. I think everyone's advice on this thread is valid, and I'm certain armed with all the info here, he'll get it figured out.
Old May 29, 2008 | 06:25 PM
Hussler's Avatar
Hussler
x2 .. that's what this forum is about.
Old May 30, 2008 | 12:39 PM
secondarychaos's Avatar
secondarychaos
Originally Posted by glasseater
your transmission is going, i wouldn't give it more than 5k miles... get it checked out
See, i had the same thing happen, and before i got to my computer, a kragen's guy told me the same thing...
funny thing is it turned out to be a fuse that was being burnt by a dead RKE module.
so,
Do you have keyless entry?
does the speedometer/odometer work?
any CEL?
Check your #8 fuse in the dash box. just another direction to try. Good luck!
Old Jun 1, 2008 | 02:52 PM
searay280's Avatar
searay280
Update, I replaced the VSS and cleared the code and it was fine for a couple of days, today when I was pulling my boat the OD light began flashing again and shifting hard.
So, is the next step getting the TC replaced?
Thanks
Old Jun 1, 2008 | 06:53 PM
RubberDuck's Avatar
RubberDuck
.................Enter Mark laughing at me....alot..... Searay, I really wish my solution would have fixed it for you. And in all reality it had a shot. But, you can't win them all. This is the point where guys like Mark and the other auto guru's are your best friend. Good luck brother. I hope you get it knocked out soon.
Old Jun 1, 2008 | 07:14 PM
Todd525's Avatar
Todd525
the TC is the next issue IF, and ONLY IF, the cel comes on AFTER running the truck in OD with the TC locked up. As stated before in either my post, or madvans, the computer ONLY reads the difference between the VSS and the TC AFTER its locked up. If you run it in town and it sets the code, and you never get it to lock up, you have another problem. If you dont get the slip code, then its time to drop the tranny, pull the tc, put new one in, and if you still have the original tranny cooler ANYWHERE ON YOUR TRUCK, GET RID OF IT. It plugs, restricts flow, and even if you have a 10 million pound rated cooler, the fluid has to run thru it for it to work. It will save you from this again (if you still have the stck coller)
Old Jun 2, 2008 | 03:45 PM
searay280's Avatar
searay280
Thanks guys for all the feedback, anyone know of a good tranny guy in North Texas?
Old Jun 3, 2008 | 04:04 PM
searay280's Avatar
searay280
Todd, I'm taking the truck in tomorrow for tranny work, what should I tell the guys regarding the tranny cooler?
Old Jun 3, 2008 | 09:27 PM
searay280's Avatar
searay280
Well, today on the way home, the flashing of the "OD" light stopped and it shifted normal. Is this just a tease and I should expect it to go right back or is my luck changing?
Old Jun 5, 2008 | 06:00 PM
  #28
Fordy1's Avatar
Fordy1
Same thing happened to me, Flashing code just quit and normal shifting again, no one responded to me on it either, I dont know which way to turn, already replaced TC and had tranny rebuilt.
Old Jun 6, 2008 | 07:47 AM
  #29
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The flashing light means something is wrong with the transmission system. It could be the trans, it could be wiring, it could be a sensor, it could be overheated. Without the code nobody knows. The code will stay in the computer's memory for about a month after the last time it flashed.
If it stops flashing it means that problem is no longer present. The code will stay in the memory.
Old Jun 6, 2008 | 08:15 AM
  #30
MADVAN's Avatar
MADVAN
X2
Its not going to fix itself.
If you investigate it now, you could possibly save yourself from a full rebuild.
The lamp will start to flash again. Thats for shure.
Searay
I would take a chance on a TC and seal install. If electrical checked good.
Bill
