Sponsored by: Kumho
Nitrogen in tires
Old May 26, 2008 | 09:08 AM
mh5500's Avatar
mh5500
Nitrogen in tires
OK, is it worth it or not? I run a lot of miles. (hotshot) Was thinking about putting in my trailer too.
Old May 26, 2008 | 09:23 AM
Steina's Avatar
Steina
CO River Rat
From what I've read, no; air is already over 70% nitrogen. It supposedly doesn't leak out as fast but you should check your tires at least monthly (I do mine weekly). Pure nitrogen is also lighter and drier than air but the weight difference is negligible. Unless some place offers it for free I wouldn't bother - JMHO.
Steve
Old May 28, 2008 | 01:01 AM
rebocardo's Avatar
rebocardo
Not worth it on a passenger car.
Old May 28, 2008 | 03:56 AM
mudgepondexpress's Avatar
mudgepondexpress
From my stock car days here is my take:
Nitrogen is dry, thus the tires don't expand (increase pressure) due to the heating of residual water in a regular air system.
I believe pure Nitrogen is a smaller molecule than naturally occuring air (I should really research this), if so it will not keep your tires inflated longer (not leak out) than does regular air (like someone stated...Hydogen, Oxygen, Carbon Dioxide, Nitrogen in some connected combination.combinations). From the track it actually leaked worse during the off week than air.
Can you really get all the latent air out of the tire? Do they flush the open carcass with Nitrogen before and during the seating of the bead? If not, what is the real goal?
They say Nitrogen doesn't harm the rubber like latent compressed air...well I have never seen a carcass rot from the inside...the outside always goes first (usually due to UV exposure).
Don't waste your money or time...it is a gimick for most but pure race cars.
Kenny
Old May 31, 2008 | 02:00 AM
wallz's Avatar
wallz
Just got new tires this week and asked the tire guy same question. His answer. The system costs money, and the money has to be recovered somehow. You pay for it. Has not really been proven to benefit from doing it. Everytime you want to run less tire psi, you are going to let out $$, and then have to pay to get it in again, and end up using regular air to get back to the shop to have them charge you to refill. He does not run Nitrogen in his tires. Don't waste your money. I didn't.
Old May 31, 2008 | 10:28 AM
YoGeorge's Avatar
YoGeorge
Fewer rim leaks on alloys...
Over the years, I've had rim leaks on cars with alloy wheels that have driven me nuts. Nitrogen, being dry, will not assist the bead in corroding, and you may have fewer problems down the road.
But paying for nitrogen? I dunno....the only vehicle that I have nitrogen in is my '02 E150, and that was because Costco puts it in for free.
For free, it's absolutely worth the price.
George
Old Jun 1, 2008 | 01:03 AM
LastSplash's Avatar
LastSplash
The earths atmosphere is 76% nitrogen so your tires are already filled with nitrogen.
Old Jun 1, 2008 | 09:12 AM
YoGeorge's Avatar
YoGeorge
Umm not quite...
Although it's primarily nitrogen, there is enough other stuff in the air (specifically water vapor) that it changes the properties enough to make a difference...
What you're saying is like--"here, this glass is 76% beer, and the other 24% is gasoline, so just drink it because it's beer...."
Old Jun 1, 2008 | 09:42 AM
desert1dog's Avatar
desert1dog
Nitrogen in Tires.
I would have to concur with all of the replies in that we are breathing nitrogen anyway and, moreover, if you travel not every town offers Nitrogen I would think.
I have read that as another reply stated that the Molecules are different in size.
I feel the best advice came from another reply in that we should check our tire pressure frequently. I use a 50:1 ratio water and dish soap, respectively in a spray bottle for the beads and also the Valve Stem checking for those little "stinker" leaks.
Personally,I feel that it is just another "bait and hook" ploy for $$$$$.
However, if you feel that you would benefit then by all means do it.
Mark
Old Jun 1, 2008 | 10:05 AM
YoGeorge's Avatar
YoGeorge
There are a bunch of Costco's around....
Mark
As I said, I have not ever *paid* for nitrogen, but have had it in 2 vehicles including my E150 now, because Costco gives you nitrogen for free when you buy tires there. Since I shop there more than weekly, it's no biggie for me to stop the van by their garage door if I want some more nitrogen in a tire (like when temps are getting colder). I do find that my pressures seem more stable over the long haul with nitrogen.
And in my old car, I did have an unexplained leakdown in one of the Costco nitrogen-filled tires on a trip, so I filled it up with regular air, went back to Costco a week later, and they used their machine to deflate the tire, fill with nitrogen, and repeat the process, again for free.
I do think nitrogen is superior, but at this point I would not *pay money* for it...which is why we have regular air in 4 vehicles, nitrogen in the van. Having "enjoyed" older cars with alloy rim leaks for many years, however, I really do like the idea of nitrogen because it doesn't hold moisture.
George
Old Jun 1, 2008 | 11:10 AM
spidermonkey's Avatar
spidermonkey
ConsumerReports.com has some interesting info on their blog. They ran a test over 1 year QUOTE "The test started on September 20, 2006 and the final measurements were taken on September 20, 2007. The results show nitrogen does reduce pressure loss over time, but the reduction is only a 1.3 psi difference from air-filled tires. The average loss of air-filled tires was just 3.5 psi from the initial 30 pressure setting. Nitrogen-filled tires lost an average of 2.2 psi from the initial 30 psi setting."
Like another person above said, I shop at Costco where they offer this for free. but for a fee, to loose 1.3 less psi over a year, doesn't seem like money well spent.
Regards,
Old Jun 26, 2008 | 03:24 PM
Damon_Tirerack's Avatar
Damon_Tirerack
Former Vendor
If you race and pressure fluctuations due to temperature changes are an issue, use Nitrogen. For street use it's nice, but isn't worth paying for. It takes 5 minutes to check your pressure once a month and it's free....
