spudders and pops
Old May 25, 2008 | 07:22 PM
joewaldner's Avatar
joewaldner
spudders and pops
1994 f150 4x4 5.0L
when the truck is still cold and I take it for a drive it goes good untill you step on the gas a little more, it slows down, spudders and pops....
when you put the gas to the floor it kicks out of the spuddering and into passing gear ... then it usually works fine for normal driving after that
any ideas ?
Old May 26, 2008 | 04:46 AM
Lazy K's Avatar
Lazy K
How long since plugs and fuel filter were replaced. Have you tried a fuel injector cleaner, like Lucas, tossed into the gas tank?
Old May 26, 2008 | 08:27 AM
preppypyro's Avatar
preppypyro
My vote would be cap and rotor. Its cheap and easy to change too.
Nothing wrong with a fuel filter and plug change either though
Old May 26, 2008 | 10:05 AM
bluesman2333's Avatar
bluesman2333
If it does it only when the engine is cold, check the temperature sensor for the computer. It might be bad, telling the computer the engine is already warm. The reason it runs better when flooring it is because the engine gets extra fuel at WOT.
Old May 26, 2008 | 10:15 AM
joewaldner's Avatar
joewaldner
I put new spark plugs in last week, despite the old ones looking good
haven't tried injector cleaner (used sea foam in the gas and through the brake booster vaccume line when I got the truck in Jan or feb?)
should I do it again ?
I was going to get new ignition wires, cap, and rotor....
I will get a fuel filter (if the problem continues)
