Throttle Cable Firewall Grommet
Old May 25, 2008 | 04:59 PM
birdhaus's Avatar
birdhaus
Man I hate it when the throttle hangs up, fuel is expensive enough as it is...
Upon further inspection, the grommet is missing from the firewall, probably lying in the road somewhere. '65 352, anyone know what and where to find this little jewel? Or a suggested retrofit? Since I've never noticed what it looked like, I have no idea what it is even made of?, (BTW, cable at the firewall is actually thin rod) Thanks Folks!
Old May 25, 2008 | 10:24 PM
merc390's Avatar
merc390
I have had a few v8 65 and 66 trucks and they were all throttle cable.The only one that did'nt was a 6cylinder.It had a z type of throttle linkage that fit through the fire wall then the carb linkage went from there.Sounds like your's may have been changed-up by someone after the cable broke.
Old May 26, 2008 | 01:41 AM
camperspecial65's Avatar
camperspecial65
the 65 and 6 FE powered trucks all used a cable type of throttle setup vs linkage.
These cables are a tough find...I dont have a spare around, but my hunch is someone on here would prolly have one kicking around.
Is your carb the original autolite 2100 ??? As far as I know, thats also the only carb used on these trucks as well originally...
- cs65
Old May 26, 2008 | 06:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
welcome to FTE
There's no parts catalog illustration that shows a firewall grommet that the cable would pass through.
AFAIK, it's part of the cable itself.
However....there are 8 different sized firewall grommets listed under the firewall sheetmetal section.
So what I need from you IF there's a hole in the firewall, is the outside diameter of the hole and the outside diameter of the cable.
Old May 26, 2008 | 10:18 PM
birdhaus's Avatar
birdhaus
Thanks, I'll go measure and take a photo, you can see where there was a screw tapped at the hole.
JefflovesF250s
Jun 21, 2014 10:35 AM
airjeff
Oct 6, 2012 03:17 PM
Big Ruth
Jul 5, 2010 07:23 PM
