No tail lights
Old May 25, 2008 | 12:06 PM
DR JOE's Avatar
DR JOE
No tail lights
Good Morning Gents,
I am posting this for a friend who has a 2004 F-250, last night he lost his tail lights. He says that the owners manuel dose not show where the fuse is. Does any one know which one it is.
Also could this be another problem???
Thanks Doc.
Old May 25, 2008 | 12:13 PM
brickie's Avatar
brickie
Number 8 15 amp
Old May 25, 2008 | 01:49 PM
DR JOE's Avatar
DR JOE
Ok the fuse is good and so are the tail lights. He has no power to the rear of the truck, ie he has no tail or tag lights. Everything else works, brake and back up.
Does any one have a wiring diagram of the trucks lighting system???
Thanks For your help.
Doc.
Old May 25, 2008 | 02:08 PM
mlb4966's Avatar
mlb4966
I would also check the fuse panel under the hood to see if something there has blown that might be related to the rear of the truck.
Old May 25, 2008 | 10:30 PM
DR JOE's Avatar
DR JOE
Well guys he called me back just confused about what to do. So I tell him to check all the connections from the back to the front. So he goes and checks them all unpluged them and repluged and walla he has lights. I am guessing that one of the connectors was either loss or just has some crud on it and thats what must have happened.
Thanks again for all your help.
Doc.
Old May 25, 2008 | 10:54 PM
albran's Avatar
albran
Good Job
You might suggest to him to go through those connectors and clean them (The trouble will probably return the next time it rains) with some contact cleaner and put some die-electric grease in them.
You can get both at your favorite auto supply or Radio Shack.
ab
